Old 10-30-2019, 10:50 PM   #1
pp270
pp270 is on a distinguished road
Default What sensor is this
What sensor is shown by green sharpie in this picture? This broke and causing p0449 code. Please advise
File Type: jpeg 7FF81C5B-9D58-4E5C-8C74-2E7535179F61.jpeg (26.3 KB, 19 views)
pp270 is offline   Reply With Quote
Old 10-31-2019, 08:42 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: What sensor is this
Which engine is that. I may be wrong but I think that's the crankcase vent, not a sensor. Hard to tell, the pic is kind of small.
However, The code is for the EVAP emissions vent valve solenoid. That valve is on top of the fuel tank
https://www.youtube.com/watch?v=_1zkDd9p9QU
Old 10-31-2019, 09:15 AM   #3
pp270
Its the 2.4L. The part that broke looks to be a separate part that snaps into the vacuum line just above the throttle body. If crank case vent do you have part number for it so I can order replacement?
Old 10-31-2019, 10:28 AM   #4
imaddicted2u
2008 AURA XE
I looked a little harder. That line comes from the EVAP purge solenoid. Could cause the P0449 and will be causing a vacuum leak.
If you can get the rest of the tube out of the hose, you might be able to epoxy it back together.
The hose with connectors is GM Vent Hose 12586630.
I can't find a part number for the other half as it seems it may be a part of the intake manifold. You need to see if the half that goes in the intake manifold can be removed. If you can get it out, it's likely a dealer item. If you can't its either somehow cobble it back together or replace the manifold.
Old 10-31-2019, 12:50 PM   #5
My two cents. If the plastic piece broke with one part still in the hose fitting, can that broken piece be removed? Once removed, perhaps a metal bushing or tube fitting the inside diameter and epoxied to the manifold can act as a structural support. The metal tube fitting into manifold and broken piece. This shouldn't affect vacuum operation. If a tube can fit snugly before epoxy, this trial fit may work to erase the P0449 error code. If it does, epoxy the piece permanently.
Is the hose a nylon tube with snap on fittings? Care is needed if these are plastic fittings. Aging dries out plastics, prone to cracking. Thermoplastics are supposed to be resilient to heat/cold cycles.
Old 10-31-2019, 01:45 PM   #6
imaddicted2u
2008 AURA XE
Can you move the hose out of the way and post a good closeup hi-res pic of the tube that's left on the manifold side? A closeup will show if the tube is broken off or if it's the connector side that's broken. Maybe we can suggest some methods to fix.
Old 11-01-2019, 09:25 AM   #7
pp270
It is definitely broken on the intake manifold side and after looking at pics of intake manifolds it is part of it. So I will attempt to epoxy as others suggested but can someone post procedure for changing out intake manifold if it comes to that.
Old 11-01-2019, 09:54 AM   #8
imaddicted2u
2008 AURA XE
You might try using a piece of rubber hose that will fit over the piece left behind on the manifold. Put some sealant on it and slip it on. Let it set up. Get a hose coupling to go in to the other end of the hose and cut the connector off of the existing hose and slip it over the other half of the coupling, use sealant or hose clamps if you have to and maybe tywrap it down.
Old 11-01-2019, 01:35 PM   #9
pp270
What kind of sealant would you recommend?
Old 11-01-2019, 02:02 PM   #10
imaddicted2u
2008 AURA XE
This stuff works good. You won't need much. Make sure none of it blocks off the hole in the manifold piece.
The purpose of that hose is to put a suction on the charcoal canister next to the gas tank so it sucks the collected gas fumes into the engine where it's burned so the hose is never under any pressure.
https://www.permatex.com/products/ga...-gasket-maker/
2000 Saturn SL2, Self Revving Engine, Coolant Sensor or Throttle Position Sensor? aygc271 S-Series Tech 5 08-06-2018 08:39 PM
P013B O2 Sensor Slow Response Lean to Rich Bank 1 Sensor 2 Bee 2008 Vue 12 01-14-2017 04:59 PM
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
error code 1137- O2 sensor bank 1, sensor 2 location? jwox L-Series General 3 03-09-2011 12:06 AM
PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) Donny L-Series Tech 5 02-16-2007 01:21 AM
