Old 10-19-2019, 10:35 PM   #1
Georgie
Georgie is on a distinguished road
Dizzy Possible starter issues on 07 3.5L AWD V6
I recently experienced some trouble starting my 07 VUE during a somewhat fresh morning (54F) and was not able to. I was able to unlock it with the remote, the headlights came on, all my dashboard lights came on but it did not start. I ended up trying three times before she finally started and I was able to get to work.
Today, I went to my local auto parts store and had the 4 year old battery tested, they said it was good and only needed charging. I took it out of my VUE and had then charge it for little over 45 minutes.
After putting it back in the truck she did the exact same thing, all dashboard lights on bu no crank. The guy at the auto parts store said to look into the ignition starter switch located in the steering column. He also suggested it may be the starter going bad.
What do you guys think?
Where is the starter located in a 07 3.5L AWD VUE?
Is it hard to replace?
What else should I troubleshoot?
Thanks.
Georgie is offline   Reply With Quote
Old 10-20-2019, 01:19 PM   #2
Default Re: Possible starter issues on 07 3.5L AWD V6
Starters are always located under the engine on one side or the other. If you examine images of starters and the three terminals on the starter solenoid, you'll see a typical configuration; the inner large terminal is never touched, the outer large terminal has two cables, battery power and a smaller wire to extend battery power to the alternator. A smaller terminal holds one small gauge wire. This is the START wire, either from the ignition switch or a starter relay in the engine fuse box. A quick and simple test for an intermittent/worn out starter would be shorting the starter solenoid outer battery terminal to the smaller terminal. This bypasses the entire starting system and powers up the starter immediately. A screwdriver or short wire jumper is all that's needed. The ignition switch should be OFF if you're under the car for safety. Either the starter runs and tries to start the engine or nothing. There will be some arcing as the starter solenoid uses about 5 amps - it energizes and pulls out the starter gear to engage the engine flywheel before battery powers the starter motor. It's difficult to determine if a starter is worn out unless this jumper results in dead silence or loud clicking (the solenoid powers up but the starter motor fails to run). Mileage is one factor, frequent short trips is another. Starters can fail in as little as 50k miles or last well over 250k miles. Intermittent operation requires eliminating battery, battery cables and starting circuit from a worn out starter.
Old 11-09-2019, 03:19 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...You can take the starter out and bring it to your local autozone to run it through a load test to see if it has gone bad, DC
Starter Issues VueofBubbles 2008 Vue 1 02-23-2015 07:35 PM
Starter issues? vasy Vue Green Line 4 02-23-2015 01:37 AM
Starter Issues Adomka S-Series General 5 01-23-2014 12:07 AM
Starter issues? AzianAssassin S-Series General 8 02-01-2010 01:05 PM
SC2 Starter Issues lockbox S-Series Tech 6 03-05-2009 07:16 PM
