Old 10-20-2019, 09:13 PM   #21
DJCharlie
DJCharlie is a jewel in the roughDJCharlie is a jewel in the roughDJCharlie is a jewel in the rough
DJCharlie's Avatar
Thumbs Up Re: Battery Dead. Jumped car and it died while driving
I appreciate your knowledge fdryer. Thanks for sticking around in the forums.
Add to DJCharlie's Reputation
Rate the quality of this post and help DJCharlie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DJCharlie is offline   Reply With Quote
Old 10-20-2019, 09:43 PM   #22
Default Re: Battery Dead. Jumped car and it died while driving
I didn't think that much about the fusible link being open as what you can see of it in the picture the insulation appears undamaged. Further it is designed to handle the full output of the alternator and go open under abnormally high current conditions.
What might damage the alternator is that it would be putting out full voltage and current due to it sensing low battery voltage. It would be working to charge a battery that it can't because there is not a complete circuit to the battery.
Never mind that the alternator output is being run through the starter motor to ground.
The alternator is not powered up by the fusible link wire. That is the alternator output. The small wire in the removable connector is the wire that lets the alternator know the battery voltage to run the alternator/charging.
Add to ssicarman's Reputation
Old 10-21-2019, 10:03 AM   #23
DJCharlie
DJCharlie's Avatar
Fired right up this morning with 14v at idle and 13.75 under load. This is probably how the alternator was functioning beforehand so I didn't damage it but I'm assuming that's a low reading so I'll eventually replace it.
Old 10-21-2019, 10:44 AM   #24
onlinebiker
That isn't bad. You should be fine.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
onlinebiker is online now   Reply With Quote
Old 10-21-2019, 12:29 PM   #25
Hurray, happy ending!
I was reading this thread and the suspense was getting to me.
People keep telling me to junk the car because of its age but i refuse.
Good for you -why throw a way a perfectly good car?
Most people are stupid (or at least, financially illiterate). There's a reason why so many people are living paycheck to paycheck, don't have an emergency fund, and don't have enough retirement savings.
Battery died last night, jumped it & drove home. Now cranks, won't start... 1999_Saturn_SC2 S-Series Tech 18 04-18-2013 04:30 PM
Radio dead, after battery died, and PCM2 fuse blew Ecomike S-Series Tech 7 02-21-2012 12:12 PM
A/C Compressor only runs if jumped straight from battery. projectpete19 S-Series Tech 12 08-08-2008 05:03 PM
'02 6cyl. AWD jumped battery -- reduced power light on grandbend Vue Tech 6 01-31-2006 07:43 PM
jumped battery - transmission problems ratso S-Series Tech 9 08-08-2004 08:35 PM
