Old 10-19-2019, 06:50 PM   #1
Core-Lokt
Core-Lokt is on a distinguished road
Default Things I Need To Know-Preventative Maintenance
Hello, all. I just bought an '05 Base Vue, and it will take me a little time to get up to speed with things. The only thing keeping it from being licensed is a windshield (which isn't terrible, but wouldn't pass due to where the crack is). That's an easy $225.00 fix, but what I would like to know is there anything that is an issue with the particular configuration that I should preemptively address. It's 4X2 with a four cylinder/5MOD. Mileage is 128,000 original miles. The clutch and fuel pump were replaced before purchase.
I do know from reading here that I need to check the sunroof drains and particularly ensure the drains are clear AND ensure they haven't come loose at the pan. Otherwise, there's no CEL/fumes/leaks/noise and it drives well. Thanks in advance for any advice.
Add to Core-Lokt's Reputation
Rate the quality of this post and help Core-Lokt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Core-Lokt is offline   Reply With Quote
Old 10-20-2019, 08:10 AM   #2
conemark
conemark is on a distinguished road
Default Re: Things I Need To Know-Preventative Maintenance
It sounds like you have another 4 cylinder base winner on your hands! Congrats!
The only sore spot I could point out is to see if the brakes have any indication of binding. A quick change of the front brake hoses take care of that known problem.
Add to conemark's Reputation
Rate the quality of this post and help conemark reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
conemark is offline   Reply With Quote
Old 10-20-2019, 03:35 PM   #3
Core-Lokt
The brakes are fine. I'll take that as there is no known issues I need to be aware of. Thanks for your reply.
I was a bit concerned reading about the 2.2L chain tensioner issue, but that *seems* to be largely ~2002-2003.
preventative maintenance Q's banman S-Series Tech 3 09-04-2012 03:56 PM
Preventative Maintenance OdieTurbo Vue Tech 7 04-26-2011 02:57 AM
Preventative Maintenance 01SL1SATURN S-Series General 3 07-02-2008 05:26 PM
preventative maintenance and other ?'s JoeH S-Series General 2 05-20-2008 03:21 PM
A little preventative maintenance greyhound bus Vue Tech 0 03-05-2007 12:41 PM
