Old 10-15-2019, 03:49 PM   #1
stbvue
stbvue is on a distinguished road
stbvue's Avatar
Default Camshaft position sensor
our 2005 Saturn Vue 3.5 V6 has check engine light on so i went to auto zone to have it read on computer and we got a code P0341 indicating its the camshaft position sensor. Does anyone know if this is located behind timing cover ? Any idea's on what i need to do to replace it?
I know theres many post on this but not much on my year Vue!
I dont mind things that go bump in the night as long as they arent in my VUE!
Add to stbvue's Reputation
Rate the quality of this post and help stbvue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stbvue is offline   Reply With Quote
Old 10-16-2019, 09:26 AM   #2
Default Re: Camshaft position sensor
Presuming Vue 3.5L V6 Honda engines are the same for Vues using this engine, this video for '09 should help; https://youtu.be/QlTISTb1KBM. Camshaft position sensor location is under and behind the power steering pump, about 3:55 into the video.
Old 10-16-2019, 10:03 AM   #3
stbvue
stbvue's Avatar
I saw this video. His is a 2009 its different, ours dont have the power steering pump. Im thinking its behind the rear timing belt cover!
Old 10-16-2019, 10:56 AM   #4
Try searching in AutoZone. Log in free then add your vehicle to find repair info. Search under engine performance and emissions control for drawings. Your camshaft sensor is shown above the cam cover and labeled as part #7.
Old 10-16-2019, 11:35 AM   #5
stbvue
stbvue's Avatar
Thanks, ill check it out!
Old 10-16-2019, 03:03 PM   #6
stbvue
stbvue's Avatar
Turns out that the camshaft position sensor is located behind the left camshaft sprocket....Which means it is behind left timing belt cover!
Old 10-19-2019, 08:18 AM   #7
atikovi
Unless the part is cheap and easy to get to, throwing parts at a problem is just a roll of the dice. You need to diagnose the issue first.
Add to atikovi's Reputation
Old 10-21-2019, 05:12 PM   #8
GTS350
GTS350 is a jewel in the roughGTS350 is a jewel in the roughGTS350 is a jewel in the rough
It was diagnosed by the OBD and assuming the car is running properly and there are no other error codes or issues (gas milage,etc) the P0341 is pretty specific.
Since it's not unheard of for the sensitive OBD to receive a random code in error, and you want to confirm the code (and only if things appear to be running normal) you could reset the code and see if it returns before you move forward.
1999 Saturn SC2 (automatic) 23,000 orig miles (9/10/16)
1996 BMW E36
1971 Holden Monaro GTS 350
1908 Buick Model 10
Its official Saturn Night has removed all doubt.
Add to GTS350's Reputation
Rate the quality of this post and help GTS350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GTS350 is offline   Reply With Quote
Old 11-05-2019, 03:47 PM   #9
stbvue
stbvue's Avatar
It was camshaft sensor... It started rough a few times and had hesitant throttling..... Replaced and fixed!!!
Camshaft position sensor? nickbrit16 S-Series Tech 4 10-19-2014 10:26 PM
Camshaft Position Sensor scrooloose 2008 Vue 4 04-20-2012 05:34 PM
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
Camshaft Position Sensor A t2oo5 S-Series Tech 4 03-13-2007 01:42 PM
camshaft position sensor ThePassenger L-Series General 1 05-05-2006 08:38 AM
