Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
Old 10-11-2019, 08:16 PM   #1
KEP3
KEP3 is on a distinguished road
2007 AURA XE
Default Smooth wheel rims possible?
On my 2008 Redline I kept losing air in two of the tires. The local tire dealer said the one with the worse leak was leaking around the TPS gasket so I replaced all four. Two weeks later the same two tires are still losing air - 5 lbs from one and 3 lbs from the other. The other two were spot on.
The rims, especially the rear one, look as though the prior owner blew the tires right off and rode on bare wheels.
Can the wheels be saved or do I look for replacements?
If the iamges don't show: https://photos.app.goo.gl/RyhCE6phVet2igMG6 https://photos.app.goo.gl/j9urefeTrUAgnSd26
Add to KEP3's Reputation
Rate the quality of this post and help KEP3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KEP3 is offline   Reply With Quote
Old 10-12-2019, 09:49 AM   #2
RedOne07
RedOne07 is on a distinguished road
Default Re: Smooth wheel rims possible?
Your tire guy should have refused working on them. They should be scrapped.
Add to RedOne07's Reputation
Rate the quality of this post and help RedOne07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedOne07 is offline   Reply With Quote
Old 10-12-2019, 08:57 PM   #3
KEP3
2007 AURA XE
RedOne07, you are a real breath of stale air. Besides that, I was afraid that would be the answer. The tire dealer is supposed to be reputable in this part of Ohio.
Thank you much. Now to decide if a set I found at car-part are worth getting.
Old 10-15-2019, 02:50 PM   #4
KEP3
2007 AURA XE
PS - You were right as rain. Per one of the best wheel repair shops the wheels are chromed aluminum. In order to fix the scuffing they'd have remove the chrome, grind & polish, then rechrome. Since I can get a pair of wheels for around $350, I think I'll do that.
BTW - The part code for chromed aluminum wheels is PD5. For polished aluminum, it's QF8.
Smooth SL MiSaturn S-Series General 4 06-30-2019 03:02 PM
Steering wheel has lost it's smooth finish toggenburg S-Series General 21 08-14-2014 12:39 PM
Set of 4 OEM Steelie Rims w/TPMS & Wheel Covers Charlie Classifieds 0 10-20-2013 11:14 PM
smooth until bulzeye S-Series Tech 11 04-20-2008 01:32 PM
Rims versus wheel covers for 98 SL2 pmark984 S-Series General 2 06-03-2006 12:02 AM
