Old 10-04-2019, 06:18 PM   #1
Jdsmitty83
Jdsmitty83 is on a distinguished road
Default Cant shift out of park
So I have a 98 sl2 and I have been having issues with the ignition dinging after taking key out. So I cleaned it with wd40 jiggled key and the problem went away for awhile. The problem came back so I took the ignition lock cylinder out to thoroughly clean it. I had a lot of problems getting it back in. I finally did but now it wont shift out of park and still have the dinging after taking k
ey out. I'm thinking it has something to do with an interlock. I did notice a pin going into bottom of ignition that seems to be bent now and no longer actuates. Any suggestions?
Add to Jdsmitty83's Reputation
Rate the quality of this post and help Jdsmitty83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jdsmitty83 is offline   Reply With Quote
Old 10-04-2019, 09:21 PM   #2
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Default Re: Cant shift out of park
I realize that you are having problems getting out of park yet may I suggest you try the simplest thing first, just as a process of elimination.
Because of the dinging sound, you might try cleaning/flushing out the ignition with CRC Electonical spray, then let it dry before trying your keys. You might have to do this twice, as was done to my ignition. Make sure your keys are also cleaned and allowed to dry.
I was told that WD40 could cause real problems because it can gum up the ignition lock according to the locksmith I recently went to for new ignition keys.
Just prior to having my new keys made and the ignition cleaned I had a small problem with getting my 98 SL2 into park, periodically, and the new keys solved that problem.
Saturn 1998 - SL2
Singer 1952 - 301A
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-07-2019, 06:49 PM   #3
Jdsmitty83
Ok I tried cleaning it again, didn't realize wd40 would do that. Still cant get out of park though. Also took off center console and disconnected interlock solenoid, still no luck
Old 10-07-2019, 07:58 PM   #4
focusofheart
I did a search, since I had no idea of the solution and found this informaton.
Go to this url and read the entire post. You may have to close out a popup to read all the text.
Please go to the posted link to read all text and see any diagrams as I only added some of the text below to the answer. I am hopeful this may help you.
https://www.justanswer.com/saturn/2l...hift-park.html
the question asked:
"I have a Saturn SL2 that is unable to shift out of park. I suspect the safety lock solenoid is the problem, but am not sure how to replace that. Any suggestions?"
the answer:
If for some reason, brake application fails to release the shifter electronically, or if service or towing requires the car to be shifted out of park without running the engine, the system can by-passed. To by-pass the system:
Turn the ignition key to the ACC position.
Apply the regular brakes.
Shift to N (Neutral). The vehicle may now be operated normally
REMOVAL
Disable the SIR System.
Remove console.
Disconnect connector from BTSI solenoid.
Using a screw driver, disconnect plastic retainers at solenoid base and at the park lock lever.
Remove solenoid from shifter assembly.
INSTALLATION
Install solenoid into shifter assembly. Connect plastic retainer at solenoid base and at the park lock lever.
Connect BTSI connector.
Verify operation. (Refer to "System Performance Test.").
Install console.
Enable the SIR System.
Saturn 1998 - SL2
Singer 1952 - 301A
Old 10-07-2019, 08:22 PM   #5
Disconnecting the interlock solenoid is the same as if the ignition key wasn't in or its turned to the ON/RUN position. The solenoid isn't powered with ignition off so the default setting is to lock the shift lever.
When you turn the ignition switch to the ACC(essory) position, you can shift out of Park position without pressing the brake pedal. With ignition On and engine running, pressing the brake pedal tells the pcm it's safe to shift so the interlock is powered up and unlocks the shift lever.
If the solenoid is dead, you have to manually move the solenoid plunger to mechanically unlock the shift lever.
Old 10-08-2019, 12:05 AM   #6
Take the braided wire cable off the shifter, not just the electrical plug. Not the safest thing in the world (can shift no matter the key status) but safer than my aunts ex-landlord who thought it a good idea to take the shift cable off the shifter entirely so there was nothing but guesswork to know what gear the stupid truck was in (way unsafe because there was nothing to stop you from dropping it to L/1 or R or P while driving).
Old 10-13-2019, 06:36 PM   #7
Jdsmitty83
Thanks for the feedback. I'm trying some of these suggestions
Old 10-13-2019, 06:40 PM   #8
Jdsmitty83
Not sure how the braided wire comes off the shifter, any suggestions?
Old 10-13-2019, 08:21 PM   #9
No idea if it's a "destructive removal" or not but I always just pried it off.
Intermittent shift interlock stuck (can't shift out of park) PlasticCarsRock S-Series Tech 12 11-07-2019 07:10 PM
No shift from park on occassion Shift Lock or??? 1996SW2 S-Series General 12 07-25-2018 01:51 PM
Can't shift out of park erick295 S-Series Tech 34 05-17-2012 01:12 AM
03 Ion won't shift Out of Park CJonesJax Ion Tech 3 09-27-2006 01:06 AM
Can't shift out of park !! Stephen Peterso L-Series Tech 6 07-13-2005 11:12 AM
