Old 09-19-2019, 08:33 AM   #1
Cavell
Default Oil in plug well.
For the 3.0 motor. I changed valve cover gaskets 5 yrs ago. Spark plug well was filled with oil. Changed front gasket last yr as itís not real hard. Oil again. Did the rear gasket last week. Oil again. Is it just a lousy design for seal? Many other cars have similar designs. Dohc? Why do vue gaskets leak?
Old 09-19-2019, 10:40 AM   #2
ScotSHO
ScotSHO is on a distinguished road
Default Re: Oil in plug well.
Probably have to redo it again. I'd use some RTV along with new seals to help out.
Now if you have a decent amount of oil blow by coming from worn piston rings, then all the RTV in the world won't help.
ScotSHO is offline   Reply With Quote
Old 09-19-2019, 11:35 AM   #3
Cavell
you can lift the front of plenum to do the front VC gasket. but not the rear. the plenum has too come off. unless you have really small hands. of course i bought cheapo gaskets. they are black. and seem like rubber. dont think they are silicone. but you would expect them to seal at first?
Old 09-20-2019, 08:17 AM   #4
ScotSHO
I've had 50/50 luck with cheap RockAuto type parts, maybe that is a problem here? Fel-Pro and AC Delco parts have never steered me wrong...
Old 09-20-2019, 10:28 AM   #5
Cavell
well, when you use a pic to pry out the bits of the old gasket and they snap into pieces you know they are cheap quality parts. a rubber gasket should not snap/break/shatter as you remove it.
Cannot plug ignition coil plug back in! AstraBrad Astra General 3 12-19-2018 10:24 AM
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto.com General Saturn Discussion 0 01-12-2017 12:07 PM
Oil Plug keeps leaking after oil change even after buying new plug? saturn95 S-Series General 13 09-13-2010 11:44 AM
Rust colored on outside of plug and plug boot coolgreany S-Series Tech 6 12-14-2004 03:26 AM
plug wires stuck on plug greasynails Miscellaneous Tech 6 07-25-2003 03:49 PM
