Old 09-15-2019, 12:00 AM   #1
pillagenburn
pillagenburn is on a distinguished road
Default New Vue Owner, looking for advice on struts and other stuff
Hey all,
I'm a new Vue owner - I got a 2005 2.2 ecotec Vue with 150k on it and an extremely blown up engine. I stuck a 43k mile motor out of a 2006 Malibu in it. It's a 5-speed and the transmission appeared to be OK so I threw it back in there.
I just got it fully driveable and noticed the struts aren't so hot - I'm wondering if the springs on these hold up also or do they generally last the life of the vehicle....
or while these are out is there a spring/strut combination or kit that you all recommend?
Add to pillagenburn's Reputation
Rate the quality of this post and help pillagenburn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pillagenburn is offline   Reply With Quote
Old 09-15-2019, 07:03 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: New Vue Owner, looking for advice on struts and other stuff
...I believe Monroe makes a strut mate kit that's a bolt in /out deal , then get it aligned, DC
Add to Vue6's Reputation
Old 09-20-2019, 07:22 PM   #3
atikovi
Numerous posts about people using quick struts and then the ride height being off. Or maybe that was for the Redlines? I don't remember, but the springs should last a long time so no need to replace them.
Add to atikovi's Reputation
Old 09-21-2019, 06:19 AM   #4
waiter21
2003 VUE 2.2L
On my 2003, I replaced the shock strut portion only, I re-used the springs mounts, etc..
Front wheel bearings replaced, they started to growl pretty bad. I tow my Vue behind my motorhome so the bearings have about 40k miles more than the odometer says
Consider replacing brake hoses at same time you do the struts. (at least the fronts) these are a weak point and cause brakes to drag.
Add to waiter21's Reputation
Old 09-21-2019, 11:32 AM   #5
Beasleylou
Beasleylou is on a distinguished road
I actually had a broken spring on my 05 in the rear.
It was over 200k when I discovered it and it had been running with low-to-no dampening for lord knows how long.
Add to Beasleylou's Reputation
Rate the quality of this post and help Beasleylou reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Beasleylou is offline   Reply With Quote
Old 09-22-2019, 05:49 PM   #6
Vue6
Vue6's Avatar
2006 VUE Red Line
...Nobody makes a quick strut for the RL , when I replaced mine I resused the spring only,bought kyb's and the strut mount with new, as for a regular vue ,I would go with the quick strut. If you reuse your spring and just buy the struts, make sure you replace the strut mounts also, you have it apart already . That way there's no question about them binding on turns or popping noises.DC
Advice for doing struts Kwillis Astra General 8 09-08-2016 08:44 AM
struts and stuff MikeNW L-Series General 8 10-18-2013 12:20 PM
Advice on new struts JerryHughes S-Series General 49 11-29-2010 06:02 PM
Vue Struts advice... mrhtwls Vue General 4 04-20-2010 11:49 AM
Break In, Oils, and Other New Owner Stuff VentureForth S-Series Tech 36 07-18-2002 07:38 PM
