Old 09-11-2019, 07:25 PM   #1
Cavell
Default Wheel squeak bearing?
Got a rhythmic squeak from wheel. Jacked up front and pass wheel bearing is a bit noisy. Ordered bearing. Today I jacked up rear and seems pass rear is noisy too. Huh? 2 wheel bearings? But, a bearing does not squeak, does it? I spun all 4 wheels and I cannot find squeak
Add to Cavell's Reputation
Old 09-13-2019, 06:12 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Wheel squeak bearing?
...I don't know if this pertains to your situation, but , my vue had a similar noise from the rear. I think it was where the half shaft goes into the rdm, the seal , possibly the spring in the seal had worn thru the rubber , and when the halfshaft rotates , it makes that noise. I managed to stop the noise, cheaply , by spraying white lithium grease around where the halfshaft goes into the rdm. The noise stopped for a while, only appearing sometimes after raining or when really cold out, just a thought that might help, DC
Add to Vue6's Reputation
Old 09-16-2019, 01:04 PM   #3
tcndeb
tcndeb is on a distinguished road
2004 VUE 2.2L
Might need weight on it to make it squeak, although a wheel bearing squeak would be a very fast squeak. The bearings I have had go bad tend to rumble more than squeak.
'04 Base Model Vue, 2.2, 5 Speed
Add to tcndeb's Reputation
Rate the quality of this post and help tcndeb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tcndeb is offline   Reply With Quote
Old 09-16-2019, 05:17 PM   #4
Cavell
Turned out be be backing plate. Lower edge next to ball joint
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 08:56 PM
Monroe Quik Struts - Squeak, Squeak, Squeak simpsondb S-Series Tech 119 07-19-2016 08:47 AM
Front wheel squeak. Vulcansat S-Series Tech 2 09-06-2012 11:10 AM
Squeak When Wheel is Turned to Right datlas S-Series General 2 04-16-2012 03:13 PM
wheel squeak briansc1 S-Series Tech 0 07-24-2008 04:05 PM
