Old 09-10-2019, 10:19 AM   #1
dads toy
dads toy is on a distinguished road
Default Dual fuel sending units?
Our 2003 Saturn Vue with 3.0 v6 is having issues with the fuel gauge not working. Since the fuel pump was starting to make a loud pump noise. I went ahead and change out the fuel pump and sending unit assembly. It's all in one piece. And its the one on the passenger side.
Question: is there two sending units on this tank? Drivers side and passenger side? Reason I am asking is the fuel gauge is still not working right. Daughter about ran out of gas because the gauge was reading wrong.
Add to dads toy's Reputation
Rate the quality of this post and help dads toy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dads toy is offline   Reply With Quote
Old 09-10-2019, 06:46 PM   #2
Default Re: Dual fuel sending units?
According to service manual info;
Fuel Tank Module Assembly (Primary)
A fuel tank module assembly is located in each side of the fuel tank. The fuel tank module assembly attaches to the upper side of the fuel tank. The primary fuel tank module assembly consists of the following major components:
*Fuel level sensor
*Electric fuel pump and reservoir bucket
*Fuel pump strainer
*Siphon jet pump
Fuel Tank Module Assembly (Secondary)
The assembly mounts to the threaded opening of the plastic fuel tank with a multi-lipped seal and a threaded retainer (nut). The assembly contains the following:
*Siphon jet pump
*Fuel level sensor
*Fuel pressure regulator
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 12:34 PM
FUEL PUMP or FUEL SENDING UNIT?.. saturn94v S-Series Tech 6 07-27-2008 10:40 AM
Fuel Sending Unit jswingchun S-Series General 1 08-21-2006 10:27 AM
Fuel pump sending units IMkenNY Vue Tech 2 04-29-2006 09:11 PM
