Old 08-22-2019, 12:08 PM   #1
Bruce Rock
2000 SL2
2006 VUE 2.2L
Default Top plug for manual transmission
Although the owners manual says the oil in the manual transmission never has to be changed, I would like to do so. Is the top plug full screw, 1/4 turn and pull or just pull? Does it also have a dip stick or do I just rely on the side plug?
Old 08-23-2019, 11:17 PM   #2
tcndeb
tcndeb will become famous soon enough
2004 VUE 2.2L
Default Re: Top plug for manual transmission
It is a full screw cap. No dip stick.
'04 Base Model Vue, 2.2, 5 Speed
tcndeb is offline   Reply With Quote
Old 08-24-2019, 08:16 AM   #3
waiter21
2003 VUE 2.2L
The DRAIN and FILL LEVEL plugs are on the side. You can get to them from the drivers side wheel well.
You can fill it from the top, but remove the fill level plug, when fluid starts coming out of the fill level, then that is the proper level.
NOTE, On mine, the drain plug didn't have a washer, and would leak a tiny bit, I took the drain plug back off and installed an aluminum washer to seal it.
I think the fill plug has an o-ring.
Manual transmission drain plug size sdotmurray S-Series Tech 2 02-20-2015 12:18 PM
Manual Transmission Drain Plug Size/Pitch Spaghettiohead S-Series Tech 9 12-06-2012 12:51 PM
03 Ion manual trans plug JeffMGrant Ion General 9 03-22-2009 09:31 PM
Will a 1997 saturn sc1 manual transmission work in my 1998 manual sl2? CARLiTO_ S-Series Tech 1 08-19-2008 08:52 PM
Manual Transmission fluid change - plug issue AJT_Leo S-Series Tech 4 08-25-2007 03:02 PM
