Old 08-18-2019, 07:45 PM   #1
Bob Panczak
Bob Panczak has a spectacular aura aboutBob Panczak has a spectacular aura about
Dizzy Whaat is the correct thermostat temp of a 05 Vue 3.5 V-6
Want to change thermostat in 05 Vue 3.5 V-6. Auto part retailers have temperature ranges of 167,170, 172, 180 and 195. What did it use from the factory?
Bob Panczak is offline   Reply With Quote
Old 08-18-2019, 08:57 PM   #2
pierrot
pierrot's Avatar
Default Re: Whaat is the correct thermostat temp of a 05 Vue 3.5 V-6
The Stant brand thermostat is set for 167 degrees F and is listed as the OE temperature setting for the part. I used to sell their parts as a former aftermarket auto parts counterman. Stant parts they were well known for their accuracy in providing the correct factory thermostat temperatures. If you were to call a dealer it's likely that they couldn't give you an answer as to what the thermostat's temperature is. However, when you look at the bottom of a thermostat there is usually a number stamped into it which is the temperature of that part.
Nevertheless, if you're still feeling uncertain then I would say that what seems clear is that no thermostat should be purchased with a temperature greater than 172 degrees F.
338,000 miles - Holy canolli!
Joe Biden for POTUS and Kamala Harris for VEEP. What follows if they get their way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Old 08-19-2019, 02:04 PM   #3
RobertGary1
RobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of lightRobertGary1 is a glorious beacon of light
Agree. Buy Stant and don't worry about the rating.
-Robert
Old 08-20-2019, 02:01 AM   #4
Here's a reprint of t-stat diagnosing in a pdf. The reference to using a scantool is not the generic reader sold everywhere. In GM service manuals, scantool means GMs Tech II. The partial mechanical specs were copied from service manual, for operating specs of Vue t-stat in your Vue.
Old 08-23-2019, 10:57 PM   #5
Bob Panczak
Thanks for the responses. I will check the rating of the current(original) thermostat in place and replace with a thermostat with the same rating.
Old 08-24-2019, 10:51 AM   #6
Cavell
is vue honda v6 only application where the honda v6 uses a 167deg thermo? what is thermo temp for a 2006 pilot or accord?
correct thermostat housing? Iraqvet05 S-Series General 14 07-23-2012 06:31 PM
Bought new thermostat Saturn 2000 SL1 rated at 180*. Is this correct thermostat? 1tallguy S-Series Tech 11 10-25-2011 09:55 PM
2000 LS2 Thermostat Issue What temp should coolant be at normal operating temp Bob Panczak L-Series Tech 3 12-14-2010 01:49 AM
Coolant Temp Below Thermostat Regulating Temp runninpapa L-Series General 2 01-30-2008 11:27 PM
correct thermostat temp simidrm S-Series General 27 10-24-2006 01:29 AM
