Old 08-17-2019, 12:50 PM   #1
4thwave
4thwave is on a distinguished road
Default Alternator wiring.
Hello,
I replaced the starter in my 2008 Aura 2.4L. I then noticed the battery light came on after awhile and in checking the alternator found a green wire beneath a rubber boot and figured out I left it off the starter.
Is there a diagram that would show exactly where that other end of the wire lands on the starter?
Thanks all!
Add to 4thwave's Reputation
Rate the quality of this post and help 4thwave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
4thwave is offline   Reply With Quote
Old 08-17-2019, 06:31 PM   #2
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Default Re: Alternator wiring.
These will probably help:
#1 is Alternator replacement
https://www.youtube.com/watch?v=0vBFjrs0ras
#2 is Starter replacement. Shows green wire from alternator to starter. It goes on the same stud as the wire from the battery. Can't charge without it.
https://www.youtube.com/watch?v=IY1MST79FM8
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-17-2019, 11:45 PM   #3
imaddicted2u
2008 AURA XE
Also,
Be aware the green wire is actually a fusible link that blows in the event on an overload or short circuit. It should always be replaced with the
Make sure it isn't chafing when reinstalled. In this case it chafed through the fusible link and the battery couldn't receive a charge anymore.
https://www.reddit.com/r/Justrolledi..._fusible_link/
Alternator wiring harness gaurdien Astra Tech 6 06-30-2017 03:03 PM
Bad alternator, transmission, or wiring? arach77 S-Series General 11 09-02-2012 10:28 AM
Alternator wiring question, pt 2 FearsOfWar S-Series Tech 10 05-01-2011 08:49 PM
Alternator Wiring Problems PlacidLifeForm S-Series Tech 21 06-23-2007 05:11 PM
94 SL2 Alternator wiring hookup? PeterB S-Series General 7 12-06-2003 12:47 AM
