Old 07-24-2019, 07:23 PM   #1
JPaganel
JPaganel is on a distinguished road
2007 VUE 2.2L
Default 2007 Vue 2.2L hard starting
So, my original thread here ended with a bit of a win. It starts. Since the hard starting is a separate problem, I figured, I'd start a new thread.
The symptoms are as follows:
Upon first turning of the key, it will catch, then stall.
If I turn the key on and off a bunch of times, it will start for longer.
Try that enough, it will start and run. It runs well, will drive normally, no issues of any kind.
I put a pressure gauge on the fuel rail. Pressure at first key on is 45 psi. Pressure after a few key on/key off cycles will build to about 55 or so.
Pressure when it's running stays a solid and steady 60 psi.
My theories revolve around the fact that the car sat a year, and gas may have gone bad. Also, the filter may not be up to snuff at this point. Or, the old gas did something bad to the fuel pump. (I hope not)
Check Engine Light is lit, but I haven't checked codes yet, can't remember where I put my scanner.
JPaganel is offline   Reply With Quote
Old 07-24-2019, 07:48 PM   #2
Default Re: 2007 Vue 2.2L hard starting
Early Vues buried their fuel filters in the gas tank, making them permanent. I presume a larger filter is used. If your Vue has an external fuel filter and have 100k miles or more, its cheap insurance to replace it. Whether it helps or not with this problem is anyone's guess.
Get the codes read, Google them and post the codes. You can always try fuel cleaner mixed in with old fuel. If you're lucky, maybe water was absorbed so a container of dry fuel (for winter use when water in fuel sometimes creates hard starting) can help mix water with fuel. Last resort would be pumping out old fuel. The best method to do this would be disconnecting the fuel line near the tank feed to the engine and place the line into a gas container, removing the fuel pump relay, locate the pinout labeling on the relay and use the info to insert a small wire jumper across relay socket terminals 30 and 87, immediately sending 12v to power up the fuel pump. If you choose to do this, be aware of flammable/ explosive fumes with plenty of ventilation, using a fan if necessary to move fumes away. This temporary manual method to power the fuel pump does not need the ignition switch turned on.
Old 07-24-2019, 09:49 PM   #3
JPaganel
2007 VUE 2.2L
Ran down to the local OReillys and got the codes read. There was a bunch of stuff, cleared it all out.
The only one that came back was P0340, "camshaft position sensor".
A quick search showed me that there actually is no CPS, but that this can be thrown by the ignition system.
I replaced both the ignition module and the coil pack in the course of trying to fix this. Perhaps this is related. I'm thinking I will try and put in the originals, see if it clears up.
Old 07-26-2019, 12:42 AM   #4
JPaganel
2007 VUE 2.2L
Well, that made no difference.
I think I mucked up the new starter from all the cranking, though...
Old 05-11-2020, 01:03 PM   #5
JPaganel
2007 VUE 2.2L
Figured it out.
Turns out, the odd thing here wasn't that it didn't start. It was that it did start.
Replacing the ECM, apparently, loses the key programming. So, the Passkey security system was cutting the fuel. Except that every so often, it didn't, and actually let it start.
Doing the key relearn procedure fixed it, and now it starts every time.
Turn the key and crank once.
Leave the key for 10 minutes until the security light goes out
Turn off for 10 seconds. Repeat three times.
hard starting saturn1957 S-Series Tech 3 01-21-2013 11:30 PM
Hard starting SW2... mikewire S-Series Tech 6 07-03-2012 01:07 PM
2007 GL Hard shifting linx3566 Vue Green Line 2 03-03-2012 10:32 AM
Hard Starting Vue Dar Vue General 15 02-26-2004 10:58 AM
Hard Starting manualman Miscellaneous Tech 5 08-09-2002 09:22 AM
