Old 07-13-2019, 10:31 AM   #1
operator john
operator john is on a distinguished road
Default 06 Vue
Driver side window doesn't work, the other three work. I took the console apart. Is it the switch or the motor in the door?? The light on the switch is still on so it still has power. Any suggestions?? John
operator john is offline   Reply With Quote
Old 07-13-2019, 05:24 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: 06 Vue
...Get a test light and pull off the connector at the motor, hit the switch and see if it lights up , if it does , the motor is bad . No light, the switch is bad, that's a start, hope that helps, DC
Old 08-03-2019, 10:50 AM   #3
operator john
Default Re: 06 Vue
ok in side door panel off ! How do I get to switch ? Or should I take off out side door panel off ?
Old 08-03-2019, 09:18 PM   #4
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: 06 Vue
The two wire circuits the go to the window motor are both by default connected to ground from the window switch, when the switch is pulled up the dark blue wire will be switch to positive power, when the switch is pushed down the brown wire will be switch to positive power. When the switch in operated the other wire will (should) continue to be grounded from the switch.
To test for ground connect the test light wire end to the positive terminal of the battery. test for power and ground with the wire connector disconnected from the window motor.
