Old 06-12-2019, 01:55 PM   #1
WildGinger
WildGinger is on a distinguished road
2007 AURA XE
Default Death Wobble! Help!
Ok so this will be a long post sorry about that! My Saturn aura has about 265k miles on her, still love her! Anyway so a few weeks ago I was getting bad resistance when releasing the brake (car wouldn’t budge unless I pushed the gas and still seemed off), I consulted my mechanic and he said the drivers side bearing was bad. I ordered both bearings and set off to change them both, the passenger side was tough but once I got to the drivers side I realized just how tough this side actually was going to be. I ended up cutting the bearing off. During my efforts in trying to get the bearing off of the drivers side I somehow popped the outer CV joint boot out, I noticed several tears and bought a new boot. After days of not being able to get the boot on I said screw in and went and got a new axle. So the axle is put in and I ended up not clicking it in all the way, I again consult my mechanic and he he pulls the axle out and cleans the spindles and puts it back in correctly. He proceeded to tell me my drivers side bearing was getting no signal from the wheel speed sensor. I pulled that bad bearing out and put another new one in and the sensor now works. The problem now is that I am having horrible random death wobble shakes! I could be doing 50 mph and then it starts and if I press the gas a little more to push through it still shakes and it will sometimes shake harder when letting off the gas and pressing the brake, but will then randomly smooth out. All of the tires and rims seem fine. The other day it did the death wobble for maybe 10 solid minutes and once I arrived at home my front drivers side wheel well was smoking and fairly hot. What have I done wrong here? I would really like to follow through and not take it back to my mechanic. Any ideas where to go now? Tie rod end? Sway bar link? Swing arm mount?
WildGinger is offline   Reply With Quote
Old 06-12-2019, 02:38 PM   #2
dano92sl
dano92sl has a spectacular aura aboutdano92sl has a spectacular aura about
2008 AURA XR
Default Re: Death Wobble! Help!
Sounds like a CV joint to me. In following above, I think you only replaced the CV on one side only?
dano92sl is offline   Reply With Quote
Old 06-12-2019, 08:11 PM   #3
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Check for seizure of the the pistons or slide pins in the brake calipers.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
explorerbigjon is offline   Reply With Quote
Old 06-13-2019, 09:07 AM   #4
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Since it is getting so hot it Sure sounds like a brake that is not releasing. A kinked or collapsed brake hose can also prevent the caliper from releasing and if getting really hot it would likely warp the rotor. If you can you feel the brake pedal pulsing back at you when you apply the brakes then the rotor is warped. If the car pulls to one side a caliper is likely stuck?
Also, when installing bearings it's important to get the weep holes oriented properly on each side or the bearing will hold water and destroy the ABS reluctor ring and sensor.
Old 06-14-2019, 05:37 PM   #5
pierrot
pierrot's Avatar
Consulted? Did he actually physically examine the vehicle or did he provide an opinion based on your description of the mechanical problem at hand? Did you ever notice an increased noise, a "humm", from the front end during acceleration and a decrease in noise during deceleration?
...So the axle is put in and I ended up not clicking it in all the way, I again consult my mechanic and he he pulls the axle out and cleans the spindles and puts it back in correctly. He proceeded to tell me my drivers side bearing was getting no signal from the wheel speed sensor. I pulled that bad bearing out and put another new one in and the sensor now works. The problem now is that I am having horrible random death wobble shakes! I could be doing 50 mph and then it starts and if I press the gas a little more to push through it still shakes and it will sometimes shake harder when letting off the gas and pressing the brake, but will then randomly smooth out. All of the tires and rims seem fine. The other day it did the death wobble for maybe 10 solid minutes and once I arrived at home my front drivers side wheel well was smoking and fairly hot.
The description here is similar to that of a caliper locking up and it relates to the first quoted fragment above. If a caliper has locked up, or is beginning to do so, the driver will notice a drag upon acceleration and an increased rate of deceleration when coasting. While there is no mention of that here, in the first quote fragment above you said that there was "bad resistance when releasing the brake." This could've been the beginning of the brake locking up. In any case, what is clear is that somethng is now causing the brake pads to be in contact with the brake rotor when they shouldn't be. Hence the pads overheated and heated up everything around them.
Neither I nor anyone else can know if you've done anything wrong thus far. A suspension problem seems unlikely. I'm inclined to agree that this is a braking system issue. Were the caliper bracket bolts tightened correctly?
I believe that the left front brake needs to be disassembled and examined (but it would be best to examine both sides). Look for irregular wear (friction material not wearing flatly [at an angle, not in parallel with the steel pad]). If a rotor is even slightly out of round a wobble will be noticed when braking. Spin the hub by hand and look for any slight wobble in the rotor. It may be difficult to see directly, but if you choose to watch a specific area of the rotor where the is a stable and even surface in the near background against which it can be viewed then the wobble will be more easily spotted. If you cannot see any wobble in that way, and assuming the vehicle has been made secure for this kind of examination, then you may view it with the wheels spinning while the engine is on and in gear, but at an idle speed only.
Since the pads were severely overheated be sure to look for signs of scorching on the friction material. It MAY be necessary to replace the pads and the rotor.
337,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Wobble... wobble... wobble... Thet S-Series General 8 02-25-2012 01:28 AM
Wobble on Highway ludcivious L-Series Tech 2 05-10-2009 01:43 AM
Halfshaft Wobble GoldenSW2 S-Series Tech 2 01-30-2008 06:55 AM
Low speed wobble ASE_Tek0312 S-Series Tech 3 05-10-2007 05:34 PM
Wobble sound floyd S-Series General 10 03-13-2006 11:37 PM
