Old 06-07-2019, 10:59 PM   #1
KyleVue
KyleVue is on a distinguished road
KyleVue's Avatar
2008 VUE 3.6L
2008 VUE 2.4L
Default AC suddenly not cooling
Drove 5 mi from home to destination today, AC worked fine as usual. 3 hours later, upon leaving, AC would not blow cold (even tho it sounded like compressor was coming on). Checked it again a cpl hrs later, same story. Other than a sudden & dramatic (& unlikely) freon leak/drain, does anyone have any ideas or experience that might point in a direction? Thx in advance
KyleVue is offline   Reply With Quote
Old 06-08-2019, 12:47 AM   #2
Default Re: AC suddenly not cooling
It's easier to start with the basics. Look in the engine bay for the compressor, startup then turn on ac, look at the compressor again. With engine on or off, the center portion of the compressor doesn't turn. When ac is turned on, the center portion (clutch plate) engages to the spinning pulley. If you don't see the compressor running, check for a blown ac fuse. If the fuse is good then the most likely reason for ac not functioning is the leak no one wants to acknowledge. Other than crash damage to the front end, no one hears ac systems rupture or leak. Leaks are usually slow enough not to hiss loudly. When ac dies, there are no hints and ignoring the number one problem (leak) will distract anyone into quick fixes like refilling that doesn't work. To address a leak or leaks is as inexpensive as buying and using a uv light and searching for dye/oil marks. Find the source of the leak then decide how to repair damage.
Old 06-13-2019, 08:21 AM   #3
KyleVue
KyleVue's Avatar
2008 VUE 3.6L
2008 VUE 2.4L
Turns out it was a very weak battery, thx!
Old 06-13-2019, 10:27 AM   #4
Wow, how wrong can a diagnoses get? Weak battery? The lights and other electrical loads should have given hints before the ac did. But what do I know? Better to have a bad battery than ac problems any day.
MPG dropped about 10 to 15% suddenly sdowney717 S-Series Tech 19 09-22-2013 09:43 AM
Suddenly Low Oil JeffTheJoc Vue General 4 03-19-2009 09:15 AM
95 SL 1 suddenly won`t start bake3187 S-Series Tech 9 03-17-2008 11:46 PM
Car suddenly shuts down after 10 min RealTwisted L-Series Tech 9 01-19-2007 01:13 PM
car suddenly stopped ~91SL2~ Miscellaneous Tech 2 08-03-2000 10:32 AM
