Old 06-05-2019, 07:39 PM   #1
ddb
ddb is on a distinguished road
2007 AURA XR
Thumbs Down Bad & sad News- Crankshaft Sensor error misfire etc..
Hi,
I was outside of the country, my car was in long term car storage. I cranked it after a while when returned and a series of errors came up, most notably
P0017 Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B
so i popped the hood and:
checked the wiring grounds on camshaft sensors - OK
replaced camshaft sensor bank 1 sensor B ( the one behind steering fluid container) - OK
checked coils and spark plugs & checked fuel injectors - OK
The car is rattling quite a lot at 3-4K rpm and throws traction errors and misfire in cyl 3 here and there, fuel economy is down and there is bit of a stall when i step on throttle..
and i know ... If is timing chain.. the car is unfix-able unfortunately. no one wants to replace chains below $2k and i have no means to lift the engine myself..
my last hope: I order crankshaft sensor, changed oil will check wiring on all sensors and coils.. i am not sure if i should do it myself because I dont have the tool and dont know how relearn CKP sensor timing after replacement?
Right?
Add to ddb's Reputation
Rate the quality of this post and help ddb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddb is offline   Reply With Quote
Old 06-05-2019, 08:09 PM   #2
ddb
2007 AURA XR
Default Re: Bad & sad News- Crankshaft Sensor error misfire etc..
i read the the manual on ckp replacement here.. so far i found only one ckp- the one behind the exhaust pipes. error indicates there are two.. still trying to find the second one..
maybe the error simply means bad correlation between the only CKP and camshaft sensor bank 1 B ( the one behind the steering fluid container)?
the funny part: after changing the camshaft sensor i couldn't find a street in LA anddrive more than 30M/hr to relearn cam/crank synch. I have to wait until tonight 10pm or so to to drive for 30min at 60MPH....
Old 06-05-2019, 08:55 PM   #3
ddb
2007 AURA XR
Originally Posted by ddb View Post
Hi,
Right?
btw.. i also ordered the actuator solenoid.. will arrive this weekend if that wont fix it ill have to dump my beloved car.. funeral will be.
Old 06-07-2019, 06:41 PM   #4
I'm curious about an outcome. The most accurate info comes from online services like Alldata or Mitchell, providing online service manuals at low cost.
Old 06-09-2019, 08:31 PM   #5
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
You might find some useful info here:
https://www.justanswer.com/saturn/bw...ode-p0300.html
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-26-2019, 05:46 PM   #6
ddb
2007 AURA XR
I finally got time to look into it. I ordered the CKP crankshaft sensor, and I just cant find it. It should be next to the starter but it is not there. I think that's a kick sensor, located next to the starter. According to the engine map it should be behind the exhaust next to the heat-block and I looked behind the oil pan and i just cant locate it.. crazy, should be the easiest thing to replace.
Old 06-26-2019, 07:43 PM   #7
Which engine? 3.5L or 3.5L?
Old 06-26-2019, 10:29 PM   #8
pierrot
pierrot's Avatar
FWIW, according to GM online parts catalogs a 2007 Aura XR has a 3.6L engine.
If your engine is a 3.6L then it has to be on the "firewall" side of the engine somewhat near the exhaust manifold. Hopefully, it's not covered by the pipe attached to it.
313,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 06-27-2019, 01:55 PM   #9
Fat fingers - I meant typing 3.5L or 3.6L. I did an initial check for engine size but a source for both engine drawings were available so I threw them together here. I find it amazing how a little imagination helps to find good info.
When the time is just right, someone might leak out the actual recipe (in kilograms, pounds or kumquats) for a nuclear bomb. Even interest some years ago in how homemade methamphetamine was made, aka hillbilly meth or cooking pot into oils (tar?) turned up vast amounts of online info but never the exact ratios. In one way, preventing this info from general online media is good against budding curiosity in young minds. Mine is just plain curiosity and fascination with chemistry in practical applications. Zero interest in consumption, manufacturing or distribution since each mode is either dangerous to one's health, illegal, toxic and explosive when ignoring flammable solvents cooking in a closed non ventilated environment (videos showing very ignorant cooks boiling flammable solvents in homes or apartments). Even Asians are traced back to early use of pot long before the '60's generation identified with it in America; https://www.history.com/topics/crime...y-of-marijuana. Who knew?
Old 06-28-2019, 11:11 AM   #10
pierrot
pierrot's Avatar
Ya know, freddy, I've got enough typos of my own in this website that I certainly can't fault anyone for errors. Heck, even after what I consider long editing checks and believing all to have been corrected I will still find something that I've done wrong after the editing time limit is over!
You've got to be one of the most generous members at SaturnFans with the amount of information you've added from outside sources and it's a great benefit to us all.
Vue 06 3.5L sensor crankshaft blind_and1 Vue General 3 01-15-2016 10:48 AM
Random misfire error code, but running smooth Edp Vue Tech 8 01-29-2013 10:18 AM
error code 1137- O2 sensor bank 1, sensor 2 location? jwox L-Series General 3 03-09-2011 12:06 AM
p0304 cylinder 4 misfire error code and P0106 MAP/Barometric MEGAMAN69 Ion Tech 5 05-28-2010 02:09 AM
Error Code P0302 Misfire pospo Ion Tech 3 06-26-2009 09:52 PM
