Old 05-24-2019, 01:02 AM   #1
jillybean
jillybean is on a distinguished road
Default Shaking Steering 2008 Saturn Aura 4 Cylinder
Hello everyone,
I've been having some issues with the steering on my 2008 Saturn Aura, and I hope you can help me figure it out.
Sometimes (not all the time, which is frustrating), the steering wheel shakes, and the steering gets a little weird, so I have to really hold the steering wheel tight so the car goes straight.
It FEELS like (and I know this isn't the case) the steering is stuck in-between 2 cogs on a gear, and it shakes back and forth trying to lock into place. It even happens when I'm at a full stop, too. The steering wheel visibly shakes. It goes for about 10-20 seconds, and then the steering is back to normal. This can happen a couple times during a 10 minute trip, or not at all...and it can happen when I'm on the highway, on a residential street, or at a full stop.
Any ideas about what the problem is? This has been happening for about a year now. The car is in really good shape, and it only has about 45,000 miles on it (it was my grandmother's car and she gave it to me when she stopped driving).
Thank you for reading my post, and I hope you all can help me like you helped me before.
Jill
Add to jillybean's Reputation
Rate the quality of this post and help jillybean reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jillybean is offline   Reply With Quote
Old 05-25-2019, 01:06 AM   #2
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2009 AURA XR
2005 ION-3 Sedan
Default Re: Shaking Steering 2008 Saturn Aura 4 Cylinder
if i'm not mistaken, there's a recall on the Aura for a steering problem.
get your vin number ready, and call GM.
in fact, you might be better checking one of the popular recall sites first.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 05-25-2019, 01:50 AM   #3
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Do you have hydraulic or electric power steering? Mine is hydraulic...
I had a similar issue, first there was vibration and slack in the wheel. The lower U-joint on the steering shaft was bad. Replaced.
Then the steering rack an pinion failed, it would jump teeth when turned without the car running.
The car still vibrated at low speeds. That was caused by 2 tires with broken belts on the passenger side. Replaced those tires and all is good.
Since your shake can happen at a full stop you likely have electric power assist.
There is an issue with electric power steering that causes the steering wheel to shake. It could be caused by a failed steering torque sensor, usually that disables the ESC. Others have found the electric power steering motor and module would need to be replaced.
Here is a video showing what can happen with electric power assist.
https://www.youtube.com/watch?v=_JCH0RoHwvc
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-25-2019, 05:14 AM   #4
imaddicted2u
2008 AURA XE
Here are a couple of videos detailing electric power assist motor removal and torque sensor replacement...
https://www.youtube.com/watch?v=P6oqoLEdPYo
and
https://www.youtube.com/watch?v=QmCO6vgOrZY
Old 05-25-2019, 05:27 AM   #5
imaddicted2u
2008 AURA XE
Yep, there was a recall for Electric Power Steering (EPS). The link states specific manufacturing date ranges. If your2 is not in those dates, as SL2 Ride says, contact GM anyway. (If you have a power steering pump, you do not have EPS)
https://www.consumeraffairs.com/news...ms-040114.html
States 2008-2009 Saturn Aura.
Old 05-25-2019, 05:44 AM   #6
imaddicted2u
2008 AURA XE
This is handy...
https://my.gm.com/recalls
Old 06-11-2019, 10:15 PM   #7
jillybean
Hi! That video totally looks like the issue I'm having. Also, I checked my VIN number and there are no open recalls for the car, so the previous owner must have taken care of that recall. I also took it in to have GM check what the issue was, and they said there were no open recalls on the car, and the couldn't figure out the problem because they didn't see the shaking steering wheel.
So, is the next step to take it in and ask them to specifically look at the Torque sensor?
Thank you so much for your help!
Jill
Old 06-12-2019, 09:50 PM   #8
imaddicted2u
2008 AURA XE
Jill
Unfortunately intermittent problems are difficult to find as components will pass testing unless the issue is present. In the EPS there are 3 components, the steering column torque sensor, the EPS controller and the EPS motor.
If GM hasn't, they should check for current, pending and history codes for potential clues. Ask if there is a calibration or tuning procedure they can do with their Tech Tool which might compensate for noisy torque sensor.
This explains how the EPS components work...
https://evwest.com/support
/General%20Motors%20Electric%20Power%20Steering.pdf
This shows how the torque sensor is replaced...
This contains details of labor times and other details...
https://static.nhtsa.gov/odi/tsbs/20...89834-2280.pdf
Old 06-12-2019, 11:42 PM   #9
imaddicted2u
2008 AURA XE
In case the root cause is a bad electrical connection, you could unplug and re-plug the two connectors on the EPS unit. This video shows how to get to them and also how to change the the EPS unit.
https://www.youtube.com/watch?v=qmnZxDfVATA
More info:
The complete EPS unit, includes torque sensor:
https://www.gmpartsgiant.com/parts/g...;t=MN5;m=ZZS69)
The torque sensor:
Old 06-13-2019, 01:00 AM   #10
jillybean
Thank you SO MUCH. Now, I know what to tell them to check. Thanks again for posting so many helpful ideas and videos. That video of that shaking steering wheel looked JUST like my steering wheel, so I'm confident you figured it all out.
I will post again once I get it fixed (I watched a video on how to replace one of the components, and it's WAY beyond my level of knowledge and ability).
Again, I really appreciate it, imaddicted2u (and SL2 Ride).
Jill
Old 06-13-2019, 08:53 AM   #11
imaddicted2u
2008 AURA XE
Something to keep in mind, if it comes down to replacing components and you opt to replace the torque sensor and it turns out that the issue is with the EPS motor controller you will be buying the torque sensor twice as it's part of the EPS unit assembly. This is why a dealer might try to sway you to replace the whole unit.
If it was me, I'd reach up under the dash and replug the two connectors on the EPS unit. This type of intermittent issue is often caused by a poor contact. They may be able to just remove the two screws holding the under dash kick panel and reach up without removing other dash panels.
Saturn SL2 steering wheel shaking Saturnmom63 S-Series General 4 12-11-2016 06:51 PM
saturn aura xe 2008 2.4L rept Aura General 0 04-16-2014 03:22 PM
Aura XE 2008 LE$ power steering problem. marginal Aura General 22 12-10-2013 07:07 PM
2008 SATURN AURA XE $11,500 too much ??? lt1george Aura General 13 09-14-2011 10:44 PM
2008 Saturn Aura Azrael_02 Aura General 46 02-20-2007 04:38 PM
