Old 05-21-2019, 12:03 PM   #1
RobertGary1
Default Nut for right forward subframe bolt broke free of weld
Was changing out an A/C compressor and the nut on the frame broke free causing the subframe bolt to spin. Very fortunate I was able to find an old school welder that had a wire welder to re-secure it. The window is too small for a fat/clumsy mig welder.
-Robert
Old 05-22-2019, 04:51 PM   #2
waiter21
2003 VUE 2.2L
Default Re: Nut for right forward subframe bolt broke free of weld
I used a small grinder and made the opening a little larger so I could get a wrench in there.
Add to waiter21's Reputation
Old 05-22-2019, 05:18 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...Same here, just used a wrench to fit on the nut thru the hole, the nut is not welded to the frame, frome the factory, it is inside a flimsy cage that is around it to keep it from spinning , also used anti seize when putting it back together, DC.
Add to Vue6's Reputation
subframe bolt question sc2 saturn S-Series Tech 5 01-07-2019 01:25 AM
01 sc2 subframe bolt help sc2 saturn S-Series Tech 2 06-08-2018 11:58 PM
hate that LCA to subframe bolt fetchitfido S-Series Tech 5 05-10-2013 09:53 PM
96SL2, broke a valve cover bolt, how to remove the bolt? HomeBase S-Series Tech 6 04-20-2008 12:35 PM
subframe bolt not going all the way in eljefino S-Series Tech 10 09-28-2004 02:10 PM
