Old 05-10-2019, 06:52 PM   #1
Nickleye
Nickleye is a jewel in the roughNickleye is a jewel in the roughNickleye is a jewel in the rough
Default '07 Int lites and locks wacky
So my 2007 Vue (V6) door locks and interior lights started getting wacky back in Aug 2018 while on vacation. Battery went dead a couple times over night. The horn would honk in the night as the alarm system activated by itself. I pulled the horn fuse out.
It happened 2-3x... then all was OK. Then in Feb 2019, randomly, the interior lights would stay on, not work, come on while driving, etc. Then the door locks began opening or closing while driving, not locking, etc etc.
A ghost in the machine !!!
I think the door locks going on / off all night ran the battery down. Maybe the lights flashed from alarm, but no horn from fuse removal.
I got a new battery in Dec 2018.
I read all I could find about this problem, learned that the BCM may be going bad, that there is an "updated" version available, that it was located behind the radio, that it would have to be programed by the dealer (Chev in my town), and that the swap would cost about $1000.
The dealer will not warranty the part or job if "I" provide the BCM.
Aaarrrggg !!!
So.....the other day I was waiting for someone, and put the key in the ACC position to listen to the radio. The door was closed. The chime was beeping away, and would not stop unless I pulled the key out.
I started playing with the driver's door jam switch.
That switch tells the BCM if the door is open or closed. AH HA....
A clue !! The BCM thinks the door is open (or closed) when it NOT.
It doesn't know what to do with the locks or lights or alarm.
Thus random wackiness !!!
I got the lights and locks and alram and chime to work properly.
It worked fine....for a while...then back to the problems. Switch acting up.
I played with it again, and all is well.
I ordered a new door jam switch ($10), and will put it in tomorrow.
If the problems persist, I will update this thread.
Add to Nickleye's Reputation
Rate the quality of this post and help Nickleye reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nickleye is offline   Reply With Quote
Old 05-20-2019, 12:27 PM   #2
Nickleye
Default Re: '07 Int lites and locks wacky
Been over a week now. No problems so far. I got the Standard brand because they are good products. Wow, the price has increased $0.44 since I got it.
Shipping was $2.99 plus tax.
I got it from Rockauto.
Old 05-25-2019, 12:24 AM   #3
Nickleye
Met my grand daughter's friend Thursday night. She a 2007 Vue also.
I told her about the troubles I had, and she said she had the exact same kind happening to her's.
I checked (played with) her driver's door jam switch, and it was bad, like mine was.
I ordered her one, and will install it when It arrives.
I used the "L" shaped tool from a Harbor Freight Mini Pick and Hook Set to pull (pop) out the switch.
Old 08-02-2019, 06:38 PM   #4
Nickleye
So here it is August 2nd, 2019 and several thousand miles later have NOT had ANY issues. That means the door jam light switch was the problem.
That's the first thing I would replace if the interior lights, horn, alarm, or door locks act up.
Old 12-03-2019, 11:26 PM   #5
conemark
conemark is on a distinguished road
Thank you for this thread. My '04 Vue started to exhibit this symptom and this gives me a great starting point.
Add to conemark's Reputation
Rate the quality of this post and help conemark reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
conemark is offline   Reply With Quote
Old 12-06-2019, 11:12 AM   #6
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
good tip, thanks for posting it
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Tinting Head & Tail Lites OZARKJAY Aura General 7 10-08-2011 12:34 AM
Left side, front & rear turn lites remain on mfedenko Astra Tech 11 01-24-2011 01:18 PM
fog lites in the vue front air inlets? vue4u2nv Vue General 7 05-23-2003 11:14 AM
Paging Hidden Lites and Introduction mysilverSC2 General Saturn Discussion 5 03-27-2003 10:13 AM
Fog lites installed! junebuggy S-Series Mods 2 02-18-2003 04:37 AM
