Old 05-09-2019, 09:10 PM   #1
FireStorm102389
FireStorm102389 is on a distinguished road
2004 VUE 2.2L
Default No rear bump stops
So I bought new rear power control arms that hold the springs, and they didnít have that hole for the bump stop to be screwed into. Contacted the place I bought them for since they were made for my year (2004) Saturn Vue and they said the parts were correct but they never saw any that had them before.
Now, the whole unit conforms to the stock one I had, all the lengths and everything match up except that missing hole and the mount for the shock is slightly off, but I donít think that is much a big deal as it has room to go in just fine. Should I install without the bumpstops or is that going to damage the shock or where it mounts to the body if I bottom out? Was thinking of just drilling a hole in the middle for it to sit in. Thoughts?
Add to FireStorm102389's Reputation
Rate the quality of this post and help FireStorm102389 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FireStorm102389 is offline   Reply With Quote
Old 05-10-2019, 09:32 PM   #2
Bruce Rock
2000 SL2
2006 VUE 2.2L
Default Re: No rear bump stops
Are you referring to the two N2 gas struts that hold the hatch up? If so, just unscrew the piston side socket and slip your old rubber bump stop on to the piston. I don't think it would hurt if you left them off either.
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-17-2019, 08:41 AM   #3
Cavell
am sure he is talking LCA. the bumpstops are never used. unless you are on hillbilly website doing 100ft jumps after 14 beers.
Add to Cavell's Reputation
Old 05-18-2019, 09:09 AM   #4
Bruce Rock
2000 SL2
2006 VUE 2.2L
Originally Posted by Cavell View Post
am sure he is talking LCA..
Yup, that makes more sense. My thinking must have been influenced by my recent experience replacing the N2 struts for the rear hatch.
Went to the junk yard for a bolt to replace one for the front bearing hub (had rounded the head). Figured I wasn't going to get away without spending a minimum of $10 so I found two struts that appeared to have been recently replaced. The replacement struts didn't have the rubber sleeve (bumper) on the piston that the original ones had. So I took them off the old and put them onto the replacements.
Loud Rear Bump Stops carvinbassplyr Vue Red Line 9 04-06-2016 09:49 AM
Aftermarket bump stops PortugalFocus Vue General 0 02-10-2014 11:13 AM
eibach pro kit, trim bump stops??? ASE_Tek0312 S-Series Mods 7 04-25-2007 10:48 PM
Trimming bump stops Hiddenlites S-Series Tech 9 04-08-2004 05:33 PM
Trimming bump stops? ProDarwin Miscellaneous Tech 3 03-16-2003 11:33 PM
