Old 05-05-2019, 06:24 PM   #1
That_dumbboy
That_dumbboy is on a distinguished road
2007 AURA XR
Default 2007 aura XR hood release problem
the lever inside the car to release the hood will not budge. What would cause this to happen and how can I fix it.
2007 Saturn Aura XR
48k miles
Second owner after parents
Add to That_dumbboy's Reputation
Rate the quality of this post and help That_dumbboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
That_dumbboy is offline   Reply With Quote
Old 05-05-2019, 07:20 PM   #2
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Default Re: 2007 aura XR hood release problem
You might be able to remove the splash pan under the front of the car and reach up with a long screw driver and release the latch mechanism. Once open, lubricate the latch liberally and work it back and forth...this video will give you an idea what you have to do.
https://www.youtube.com/watch?v=mCQCatoG9Rc
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-05-2019, 07:57 PM   #3
imaddicted2u
2008 AURA XE
Ignore my previous post. I just looked at mine and found the Radiator and AC condenser looks to be blocking access to the latch.
Try to have someone attempt to operate the hood release in the car while you press repeatedly on the hood above the latch. Hopefully it works it enough to release it. If it does lubricate the latch.
If it doesn't open then try to spray penetrating fluid between the grill and hood and soak the latch and repeat pressing on the hood while someone operates the latch.
I just lubricated me so I don't end up with a seized latch too.
Hood release problem Saturngirl4ever Vue General 5 10-07-2018 05:06 PM
2007 Aura trunk release not working pjm0322 Aura General 15 01-25-2017 01:25 PM
Hood release cable crimped, hood stuck in a released state Cards Ion Tech 3 01-06-2009 07:05 PM
2003 saturn ion hood release problem north52ice Ion General 2 12-09-2006 11:49 AM
hood release problem Spacepope Ion General 31 02-08-2005 09:48 PM
