Old 04-23-2019, 09:09 AM   #1
xlevix10
xlevix10 is on a distinguished road
Default 2007 Aura XR TCS issues/rattling
I have an 07 Aura XR with 163,000 miles on it. Within the last few days, I've starting having issues with the traction control where it will constantly turn off and say "Service Traction." I do also get an engine code, P0011. I've honestly experienced intermittent issues with the TCS where it'll turn off and say to service it, but it would happen once in a blue moon, but now it happens many times in a single trip.
When it started, I would hear a rattling noise that seems to come primarily from the front driver side, although I have heard it on the front passenger side, too. It would only happen when I would turn, but now it's happening when driving straight, and is much worse when accelerating quickly.
Has anyone experienced this or anything similar, or have any ideas what the issue could be?
Add to xlevix10's Reputation
Rate the quality of this post and help xlevix10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xlevix10 is offline   Reply With Quote
Old 04-23-2019, 09:56 AM   #2
Default Re: 2007 Aura XR TCS issues/rattling
163k miles suggests there may be additional age related wear and tear on parts that may be announcing themselves. TCS is an abs function. Abs error codes can be decoded at some/all AutoZone stores with readers capable of decoding abs error codes. Call ahead to verify their readers can read abs errors.
P0011 is about variable valve timing and errors detected as either valves too advanced or retarded.
Old 04-27-2019, 08:46 PM   #3
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Good description of P0011. I've had that code before. It was intermittent and once cleared it did not come back. So clear yours, if it doesn't come back you're good. If a camshaft position sensor is failed, it will usually throw a code to tell you which one is failed.
https://www.autocodes.com/p0011_saturn.html
Video describing camshaft position sensor replacement, there are 4 of them.
https://www.youtube.com/watch?v=FuiViOoA2MI
As far as the traction control errors go, a code reader that reads engine codes will not display codes from other modules. I had an issue with the front driver side wheel bearing that caused me intermittent traction control issues that eventually became permanent Service Traction control, ABS and Stability control messages. The wheel speed sensor is integral to the bearing assembly. In my case the bearing was good but the bearing was improperly installed. I posted some pics in this thread...
http://www.saturnfans.com/forums/sho...=wheel+bearing
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-27-2019, 08:54 PM   #4
imaddicted2u
2008 AURA XE
The rattling might also be caused by worn out stabilizer links.
2007 Aura XR issues ??? alfisalive Aura General 8 05-15-2014 04:04 AM
2007 Saturn Aura XR Sunshade Issues? zam290 Aura General 5 07-26-2013 11:34 PM
30 MPG on 2007 Aura XE? Gas mileage issues Anjey Aura General 26 08-29-2011 11:09 PM
2007 Aura Driver's Seat Issues ecbahs Aura General 4 04-20-2008 03:25 PM
Issues with my brand new 2007 Aura XR.... cisco0623 Aura General 10 12-15-2007 01:49 AM
