Old 04-17-2019, 08:36 PM   #1
Buckmeister
Buckmeister is on a distinguished road
Default 2005 saturn vue right rear door no power
Window wont go up and the lock button on the door quit working....
Before I go pulling wires, anyone know if there is a fuse directly linked to this?
Add to Buckmeister's Reputation
Rate the quality of this post and help Buckmeister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Buckmeister is offline   Reply With Quote
Old 04-18-2019, 11:07 AM   #2
Woodpecker
Woodpecker is on a distinguished road
Default Re: 2005 saturn vue right rear door no power
With one door not having power, I'm betting on a wiring issue. There's not a fuse that controls those in one door individually. I'd start at the bottom of the door and check where the wires go into the door. It's easier to see if you open the front passenger door and look down. From there, I'd take off the door panel and see what's going on.
Add to Woodpecker's Reputation
Rate the quality of this post and help Woodpecker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Woodpecker is offline   Reply With Quote
Old 04-18-2019, 07:44 PM   #3
Buckmeister
So i took it off the track, pushed it up and stuck a shim in it.
I was wrong with my original post, that door has a manual lock, so it is just the window that doesnt work, not the power lock.
The light on the button up front for the window is on, so i do not think it is that button, because the window button on the back door doesnt work also. So i can rule out the switches.
The window motor just stopped working without any warning sign, that is unusual in my experiences with window regulators.
I have the door panel just kinda sitting on the door for quick removal. I am going to cut the rubber wire cover open and do more wire checks before i confirm bad regulator assembly.
Any other ideas or suggestions?
One question I have is the door itself, the inside shell, does it come off as easy as taking off all those screws all around the door? Just so id have a very broad very of everything going on inside of the door.
Thanks.
2005 Ion 4 door rear axle issue casterman Ion Tech 0 03-24-2018 08:23 PM
Power rear door lock not working BennySL2 S-Series Tech 3 07-18-2011 01:18 PM
Rear door power lock rover3l Aura General 21 12-29-2010 09:42 AM
How to get to Rear Door Power Lock HV Fam Wagon L-Series Tech 0 07-11-2010 04:51 PM
Rear door on 2005 Relay lightstarcom Relay Tech 5 03-08-2010 11:21 PM
