Old 04-13-2019, 09:07 PM   #1
jnoonfelt14
jnoonfelt14 is a jewel in the roughjnoonfelt14 is a jewel in the roughjnoonfelt14 is a jewel in the rough
jnoonfelt14's Avatar
2007 AURA XE
Default Short Throw Shifter
Since I have seen a earlier post of someone modifying a Cobalt SS shifter assembly to fit the Vue. I took took his comment into consideration about the Cavalier short throw shifter possibly being able to fit the Vue without modifications. I wanted a different shifter myself so I decided to take a stab at it.
I did some research on the shape of the shifters between the Vue and the Cavalier and they are almost identical. I bought the shifter myself and tried to make it work. It went in with almost ZERO modification. All I had to do was trim the slot of the back of the shifter assembly larger towards the bottom (as the shift to third would cause the cable end to hit and rub the housing). All I had to do was cut the rubber handle off the shifter to be able to remove the boot and the collar that holds the shifter in. Surprisingly, the handle is indeed molded onto the shifter! Additionally I had the transplant the original shifter bushing from the Vue that connects to the black cable onto the Cavalier shifter as the one provided is too big. Other than those few things, it is a direct bolt it.
If you have nay questions or opinions, let me know and I'll be happy to assist.
Add to jnoonfelt14's Reputation
Rate the quality of this post and help jnoonfelt14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jnoonfelt14 is offline   Reply With Quote
short throw shifter quiksc2 S-Series Mods 13 01-22-2011 03:01 PM
FS: 91-02 S Series Short Throw Shifter & AEM Short Ram Air Intake dacuda Classifieds 0 06-10-2006 07:39 PM
Short throw shifter? IDLE S-Series Mods 7 09-27-2005 10:21 PM
Short throw shifter Batman87 Mods and Performance 11 08-05-2005 08:16 PM
FS: SPS short throw shifter AustinGSrider Classifieds 10 05-06-2003 03:40 PM
