Old 04-10-2019, 09:10 PM   #1
Buckmeister
Buckmeister is on a distinguished road
Default Radio wiring advice
Okay so im finally getting around to replacing my head unit, everything going good fairly simple process, but i have a question.
There is a blue wire for the new connector, its for "power antenna/amp turn on", but there is no blue wire on my 2005 saturn vues connector.
Also, what is the gold strap that was on the back of my factory head unit, and where does it go now?
Thanks.
Add to Buckmeister's Reputation
Rate the quality of this post and help Buckmeister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Buckmeister is offline   Reply With Quote
Old 04-11-2019, 10:59 AM   #2
Woodpecker
Woodpecker is on a distinguished road
Default Re: Radio wiring advice
Thanks.
The blue wire is not used. On a vehicle with a power antenna or auxiliary amp, this wire would be used.
As to a gold strap, my '07 didn't have one. I'd assume it's a ground strap for the radio. You could attach it with a small screw to the side of the new head unit, which should have several screw holes that you won't be using. They are there for different mounting styles. Your head unit probably came with an assortment of screws. This is assuming the strap is long enough to reach. Other than that, it probably won't matter if you leave it off.
Add to Woodpecker's Reputation
Rate the quality of this post and help Woodpecker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Woodpecker is offline   Reply With Quote
Old 04-11-2019, 07:00 PM   #3
Buckmeister
Left the gold strap off. New heas unit working very well, i am happy.
Purchased a $21 radio/bluetooth head unit and a $13 mounting kit from Wal-Mart. The mounting kit i think was un needed, as i could of used the one on the original head unit, but I used it regardless.
Wiring Diagram or wiring advice dasdream Astra Tech 3 07-25-2017 10:13 PM
Radio Wiring Help Arocee Ion General 1 02-04-2016 01:36 PM
'05 Radio Wiring Harness for Aftermarket Radio Crawdaddy Ion General 16 05-12-2005 01:33 AM
Radio Wiring scottl480 Vue General 7 05-12-2004 08:22 AM
radio wiring help Marvin18 Ion General 11 08-17-2003 12:50 PM
