Old 04-09-2019, 08:20 PM   #1
Buckmeister
Buckmeister is on a distinguished road
Default Door arm popping
What is this thing? Picture attatched.
Pops on all 4 doors they all move whenever the pop happens, drives me nuts, grease did nothing.
EDIT: Found out its called a door check. Would there be any problems besides the door not staying open if they were removed?
Has anyone found an alternative to this issue than replacement? New ones i can find are 44 a piece or so.
Add to Buckmeister's Reputation
Rate the quality of this post and help Buckmeister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Buckmeister is offline   Reply With Quote
Old 04-10-2019, 06:43 AM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Door arm popping
...You do need those ,otherwise the door will swing wide open in the wind with no stop. Try visiting your local junk yard for a temp fix.DC
Add to Vue6's Reputation
Old 04-10-2019, 08:13 AM   #3
burnt orange
burnt orange is on a distinguished road
Wipe the grease off..pull one of the door panels off, not that hard.
Look inside and see whats causing the noise..Do you drive a lot of dirt roads? Sometimes dust can accumulate inside the door and cause problems...
Add to burnt orange's Reputation
Rate the quality of this post and help burnt orange reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burnt orange is offline   Reply With Quote
Old 04-10-2019, 04:24 PM   #4
Buckmeister
When you open the door, that area where the grease is, it looks like the arm moved where that grease is and you hear a loud pop.
Is the only long term thing to do is buy the expensive door arms?
Old 04-11-2019, 02:54 PM   #5
Grape_Ape
Grape_Ape is on a distinguished road
New are a little over $30 most places, not terribly expensive. You could try a junkyard, but they do wear out, so who knows how long a new one would last. I'd pull the door panel off first and see if they can be clean up and se exactly what's going on. Grease is not usually a good fix for them, as it attracts dirt. I'd use a dry graphite lube.
Add to Grape_Ape's Reputation
Rate the quality of this post and help Grape_Ape reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Grape_Ape is offline   Reply With Quote
Old 04-15-2019, 12:26 PM   #6
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
I packed driver passenger with grease and no more pop. Looked to have a compression spring inside. No alternative, dealer part only.
Add to JefferyC's Reputation
Rate the quality of this post and help JefferyC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JefferyC is offline   Reply With Quote
Old 04-15-2019, 04:37 PM   #7
Vue6
Vue6's Avatar
2006 VUE Red Line
..Did you check them to see if they have a crack in them,at the small end? That is why they usually start popping ,mine did on the driver's door, that grease will help for a bit, but eventually it will get worse, DC.
99 MP3 popping 3'rd Jack Black S-Series General 3 05-24-2015 12:53 PM
popping when fan is on? athensm50 S-Series Tech 1 03-14-2014 04:30 PM
Astra door check popping Spaztrick Astra General 7 03-07-2013 08:19 AM
L200 Front Door Popping Noise paskitti L-Series Tech 8 02-27-2007 08:34 AM
Popcorn popping sounds from drivers side door/window flavoredair Vue Tech 1 03-15-2006 10:25 AM
