Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 04-09-2019, 02:04 PM   #1
Snotrockits
Snotrockits is on a distinguished road
2007 VUE Red Line
Dizzy New Strut Recommendations
I just took ownership of an 07 red line fwd (and love it!). Looking at new struts/shocks. I want to keep the red line ride height and want to keep the OM springs. Economically my thoughts are to get a set of decent pre-assembled quick struts, disassemble them and replace the springs with the red line springs. This is as compared to having to get the strut, bellow, spring seat and strut cap separately.
Also need new shocks in the back and will be replacing spring insulators while I'm back there.
So two part question:
1) Has anyone had experience swapping red line springs onto struts, or should I just go the route of buying strut parts piecemeal?
2) Any brands of pre-assembled strut that are recommended or people have had success with that wont break the wallet or brands to avoid all together?
Thanks!
Add to Snotrockits's Reputation
Rate the quality of this post and help Snotrockits reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Snotrockits is offline   Reply With Quote
Old 04-09-2019, 05:51 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: New Strut Recommendations
...I would buy a set of kyb struts, shocks, and a set of moog bearing plates. You do need the spring compressing tool to take your old set apart, to reuse the redline springs. Also you will need to invest in a pair of alignment bolt/cams when you go and get it aligned afterwards. An impact helps with the strut bolts,it's not that bad of a job, hope that helps, DC.
Add to Vue6's Reputation
Old 04-09-2019, 06:14 PM   #3
Snotrockits
2007 VUE Red Line
Thanks! I was actually looking at the KYB's. Never took into consideration about that camber bolt. Since the ride height isnt changing, is the camber bolt necessary? Also: Where abouts is that camber bolt installed?
Old 04-09-2019, 06:16 PM   #4
Snotrockits
2007 VUE Red Line
To reply to myself: Ah! I see, its a bolt for adjustable camber. Nifty!
Old 04-10-2019, 06:41 AM   #5
Vue6
Vue6's Avatar
2006 VUE Red Line
...Yea, you will need it for an alignment, especially with new struts, DC.
strut recommendations lord_varon Vue General 2 08-29-2015 11:05 PM
Strut Mount Recommendations AlainMDavos S-Series General 1 11-27-2011 06:29 PM
Strut recommendations? Deep6 L-Series Tech 12 06-22-2010 10:46 PM
Strut Replacement; any recommendations? usa4624 L-Series General 7 02-07-2006 09:48 PM
Replacement Strut Recommendations avlonfrg S-Series General 15 08-01-2005 04:01 PM
