Old 03-22-2019, 11:49 PM   #1
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Replaced rack and pinion steering gear
I backed out of the driveway a few days ago and the steering wheel ended up at 90 degrees out, by the time I got to the end of the road the was upside down. Got the car turned around and back home. Pulled in to the driveway and the wheel was back to normal. With the engine off, I could make the rack jump teeth. Not safe. Put the car on jack stands and prepped to change the rack out.
I followed the steps in this video:
https://www.youtube.com/watch?v=IXmGVpyKp5Y&t=190s
I ran in to a big problem when I tried to loosen the pinch bolt on the steering shaft knuckle that attaches it to the rack. It slipped and rounded off the bolt head. Due to the tight quarters, I had a heck of a time getting the bolt pressure released to get it apart. Finally got the rack out and back in. Not a fun job but what a difference it made in the handling.
Two days later...the power steering pressure line starts leaking. I'll be changing that next week when the new one gets here.
Old 05-07-2019, 01:31 AM   #2
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
Default Re: Replaced rack and pinion steering gear
There is a recall on the steering for these cars. Not rack related though, I don't think.
SL2 Ride is offline   Reply With Quote
Old 05-07-2019, 06:42 AM   #3
imaddicted2u
2008 AURA XE
Right, the recall is for electric power assisted steering.
If you're replacing a rack and pinion gear consider Detroit Axle pierrot General Saturn Discussion 0 02-02-2017 06:12 PM
05 Ion 2 heat shield for Steering rack/pinion TGP Z34 STE Ion Tech 0 08-13-2016 03:21 PM
Steering rack and pinion possible problem. awakenthedead Vue Tech 15 04-19-2015 11:31 AM
Rack and pinion or steering column motor. NickL30 Ion General 3 12-07-2013 06:53 PM
93' SC2 Rack & Pinion Steering replacement... ClosetGeek S-Series General 8 02-20-2010 06:28 PM
