Old 03-17-2019, 11:01 PM   #1
<<Aura_XR>>
<<Aura_XR>> is on a distinguished road
2007 AURA XR
Default 2007 xr p0366 & p0365
Good evening.
2007 S.A. XR with 177,800 miles. Been having the P0017 code for "Crankshaft Postition - Camshaft Position Correlation - Bank 1 Sensor B" for the 2 years we've owned it. Never stopped the car of course, and its the only code ever. Last weekend, replaced the exhaust Solenoid on bank 1 (right side near firewall). Code came back within 500 ft after test drive.
Tonight, I replaced sensor B, the exhaust camshaft position sensor. Cleared code and test drove it a couple miles with no issue at all, no code. Kinda seemed to run smooth even at idle. Silly me, I figured it was good to go.
Parked it, ran scan tool, no codes! yeah!
Tried to start it, and it seem to take a couple seconds longer and I almost shut it down as it was abnormal. Of course, CEL came on. Shut it down and ran the scanner.
1/4 P0366 Camshaft Position Sensor B Circuit Range/Performance (bank 1)
2/4 P0365 Camshaft Position Sensor B Circuit (bank 1)
3/4 P0365 Camshaft Position Sensor B Circuit (bank 1)
4/4 P0366 Camshaft Position Sensor B Circuit Range/Performance (bank 1)
I cleared the codes, powered off. I then restarted the car and it started normally, no hesitation.
Thoughts as to why that happened? I of course will update if it happens again.
Add to <<Aura_XR>>'s Reputation
Rate the quality of this post and help <<Aura_XR>> reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
<<Aura_XR>> is offline   Reply With Quote
Old 03-18-2019, 08:30 PM   #2
<<Aura_XR>>
2007 AURA XR
Default Re: 2007 xr p0366 & p0365
Car started, even remote started twice today, ran great. Then this evening, my son left and it took a couple seconds before it would fire and start. P0365 appeared. He got back, I cleared the code, started rough, and I did this a couple times. I haven't gotten back to the car after his latest trip but my guess it is still an issue.
Anyone have ideas as to why this code as appeared? The previous P0017 as not returned.
Old 03-19-2019, 07:12 PM   #3
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
May not be related to your issue but my XE 3.5L threw a camshaft sensor code when the starter solenoid was failing and the starter was chattering sometimes when I would try to start it either by the key or the remote.
You probably looked the codes up already but just in case, here is a description:
https://www.engine-codes.com/p0365_saturn.html
and
https://www.engine-codes.com/p0366_saturn.html
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cannot clear P0365 to save my life! congerz83 Ion Tech 9 03-23-2016 07:08 PM
P2A00, P0135, P0365 codes cindycated Astra Tech 2 08-02-2013 11:11 PM
Engine Codes: C0899 & P0366 Help glxpassat Outlook General 2 03-10-2013 05:42 PM
Vue Leads Equinox in 2007 Sales as of 7-1-2007 mikec Vue General 2 07-06-2007 06:52 PM
Vue Leads Equinox in 2007 Sales as of 2-28-2007 mikec Vue General 6 03-13-2007 04:42 PM
