Old 02-18-2019, 11:44 PM   #1
eclipsor
eclipsor is on a distinguished road
Default Steering wheel is off-center and tilt changes when driving
Hey, so my steering wheel has been off-center for a while, and I just fixed somethings before getting a proper alignment done.
A while ago I replaced my outer tie rods, and my steering wheel was consistently off-center for a while (even after some bad alignment jobs).
Yesterday I did the inner tie rods and replaced all my struts. After doing this, my steering wheel was off-center as usual, but not at its usual position.
In fact, the off-center position/angle/tilt seems to change as I drive. If I make a right turn, it seems to start tilting towards the right, when I make a left sometimes a bit to the left. Then sometimes it seems to be a bit straight.
Tomorrow I plan on getting new tires, and I was planning on getting an alignment right after that.
Is this something that should be fixed with a proper alignment? Or did something go wrong with the new inner tie rods or struts?
Add to eclipsor's Reputation
Rate the quality of this post and help eclipsor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eclipsor is offline   Reply With Quote
Old 02-19-2019, 12:40 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Steering wheel is off-center and tilt changes when driving
If you live in the rust belt, you might want to closely inspect your subframe. They tend to rot out over the years.
Add to bluesl2's Reputation
How can I center the steering wheel on SC1 desertrat S-Series Tech 6 05-22-2011 07:53 PM
1. Steering wheel off center SaturnIONSLVUE Astra Tech 16 06-19-2010 05:15 PM
Upgraded to leather steering wheel; now wheel is off center kkspeed S-Series Tech 8 04-16-2008 07:14 AM
L Steering Wheel Off Center Fix? Yankeez L-Series Tech 6 07-17-2003 11:13 PM
steering wheel of center satfanNJ General Saturn Discussion 3 03-15-2001 02:11 PM
