Old 02-15-2019, 11:55 AM   #1
atikovi
Default 2006 V6 AWD transmission problems
Just got it and only has 95,000 miles. After it's warmed up it drives perfectly normal. When cold it might not upshift out of the lower gears until 3000 rpm and then bang into gear when it does. Yesterday I changed the fluid 3 times with the Honda DW1. Old fluid was dark but no trash on the magnet. Drove fine afterward but it was still warm. This morning when cold, it was doing the same as before, plus now it seemed to go into a limp mode, like starting off in 3rd. Turning the engine off and on cured the limp mode but it was warm by then. Scanned for codes and have P0746 clutch pressure control solenoid 1 stuck off. From what I read these solenoids are external. Anybody had a similar code come up?
Add to atikovi's Reputation
Old 02-15-2019, 07:23 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2006 V6 AWD transmission problems
I don't recall seeing DTC P0746 code but also didn't monitor forum for several months.
I suspect you have access to service documents but will attach a few extracts just in case.
I try to visit forum daily but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 02-17-2019, 11:51 AM   #3
atikovi
I have a factory service manual for 2006 Honda Pilot and Ridgeline but not for a Vue. Should be similar for the transmission though. Thanks for the diagrams. I'll start into it after I'm done with this major brake job I'm doing on it. Hope it's as simple as a bad solenoid or the connector to it.
Old 02-18-2019, 10:07 PM   #4
atikovi
Got the solenoid unit out which was a pain just to get to. They pass the resistance spec and function properly when I power them up, but one of the valves doesn't move when I remove the power. Looks like it's stuck in the bore.
Old 02-21-2019, 07:43 PM   #5
atikovi
Replaced the above with a junkyard part and the Vue shifts like new now.
Old 02-21-2019, 08:01 PM   #6
far2grumpy
far2grumpy's Avatar
Great results!
I'll have to remember code P0746.
Old 03-18-2019, 03:34 PM   #7
WorldTour
WorldTour is on a distinguished road
2004 VUE 3.5L
2001
Out of curiosity, did you do a generic OBD scan or was it a Saturn specific enhanced scan?
Add to WorldTour's Reputation
Rate the quality of this post and help WorldTour reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WorldTour is offline   Reply With Quote
Old 03-18-2019, 03:58 PM   #8
atikovi
Specific scan of the powertrain module.
Old 03-18-2019, 04:28 PM   #9
WorldTour
2004 VUE 3.5L
2001
What scanner were you using or was it a shop that scanned it?
Old 03-18-2019, 04:31 PM   #10
atikovi
I use a clone Tech2 and an Autel 906BT.
Old 03-18-2019, 06:01 PM   #11
WorldTour
2004 VUE 3.5L
2001
Awesome. Tech2 clone working good for you? Any glitches? I have been wanting one for a while.
Old 03-18-2019, 06:03 PM   #12
atikovi
Have it for 5 years now. Works just fine.
Old 03-18-2019, 10:00 PM   #13
RobertGary1
Great job
2006 ion a/c problems ! dustbowl Ion Tech 6 06-04-2013 12:00 PM
2006 ion 2 a/c problems brttmattson Ion Tech 2 10-31-2009 12:56 AM
2006 Vue - Problems? mellissam Vue General 48 09-27-2006 10:00 PM
2006 Relay Problems saturnrelaypain Relay General 5 08-15-2006 01:34 AM
Common problems with 2006??? tominsky Vue General 30 03-12-2006 07:42 PM
