Old 01-11-2019, 05:02 PM   #1
bromli
bromli is on a distinguished road
bromli's Avatar
Default Trunk Reflector Removal '00 LS1
Are there any diagrams or tutorials on how to remove the trunk reflector for pre facelift L series sedans? Mine is looking a little rough around the edges and there appears to be mud underneath the plastic. I have seen pictures with them removed but I don't want to guess as I go and break something. Thanks guys!
Add to bromli's Reputation
Rate the quality of this post and help bromli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bromli is offline   Reply With Quote
Old 01-11-2019, 05:27 PM   #2
floridasl22002
Default Re: Trunk Reflector Removal '00 LS1
I can offer no suggestions on the L series as my sons is the later model which didn't have the boot trim. That said, my other son had an S series which had the reflective trim across the trunk rear and I removed that without instructions.
You will need to carefully check around the trim piece for any obvious screws & fasteners. I would reckon that you will find them on the inside of the trunk. So to release the trim you would work from the inside. Saturn also used some double side foamy type tape to hold pieces to stop them rattling. I found all those pieces to have simply rotted away. I replaced them with the one side foam draught proof strip you vcan buy from Lowe's/HD. Works just as well.
Hope this helps.
Old 01-11-2019, 05:37 PM   #3
pierrot
pierrot's Avatar
There is nothing unusual required to remove the rear reflector from the from the trunk lid. There are nine small metric nuts which screw on to nine corresponding studs that hold the reflector in place.
1)Four of them are easily seen on the far-left and far-right of the trunk lid as it's opened.
2) One is located at the middle of the reflector,
3) and two other pairs are located to the right and left of the middle retaining nut.
I can't recall for certain, but you may need to remove the license plate bulb sockets which are located on the inside of the trunk lid before separating the reflector from the lid.
311,000 miles - Holy canolli!
Add to pierrot's Reputation
'94 Trunk Reflector TVETTER S-Series Mods 3 01-30-2014 06:04 PM
trunk reflector quiksc2 S-Series Mods 23 08-21-2007 09:39 PM
Trunk Reflector '94 SL2 AFIndependant2k S-Series Mods 13 05-14-2007 11:10 AM
sl2 trunk lid reflector removal swoker183 S-Series Tech 3 10-22-2002 02:54 PM
trunk lid reflector swoker183 S-Series Mods 14 09-06-2002 01:08 PM
