Old 01-10-2019, 10:32 PM   #1
chris's sc1
chris's sc1 is on a distinguished road
Default Swap questions
When swapping from sohc to dohc. I need motor trans wires and computer.
Are there any dash components that would have to be swapped over.
Add to chris's sc1's Reputation
Rate the quality of this post and help chris's sc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chris's sc1 is offline   Reply With Quote
Old 01-11-2019, 10:42 AM   #2
Default Re: Swap questions
Unless it's a '91-'94 you can leave the wire harness alone.
Only the cluster should be swapped over if it's a '91-'99.
Transmission only needs to be swapped if it's an automatic, unless it's a '96-'02 and you have to keep cruise control working.
Old 01-11-2019, 07:12 PM   #3
SLfun
SLfun will become famous soon enough
2006 ION Red Line
You might want to swap over the instrument panel so you'll have the correct redline and higher speed on the speedometer. But it'll run fine without it.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 01-15-2019, 07:23 PM   #4
saturny
saturny has a spectacular aura aboutsaturny has a spectacular aura about
The exhaust is different, and so is the throttle cable. You might also need the air injection depending no the model (Cali vs Federal). Oh, fuel line's probably different too.
2000 Saturn SL1 (w/ DOHC) automatic - 273k
Add to saturny's Reputation
Rate the quality of this post and help saturny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturny is offline   Reply With Quote
Old 01-16-2019, 11:58 AM   #5
chris's sc1
ok so mine is a 97 sohc manual. donor is a 97 dohc manual. its been trashed pretty bad and has been hit.
ill need dohc motor using the trans i have but get the wiring harness that goes with that dohc motor.and get the cluster
Old 01-16-2019, 12:08 PM   #6
trottida
trottida's Avatar
Why wouldn't you take the DOHC motor, DOHC trans, DOHC engine wiring harness and DOHC PCM? You can remove the motor, transmission and engine wire harness as a complete assembly. The DOHC transmission is geared more towards performance and RPM's will be higher in 5th gear. It takes a marginal hit in fuel economy but to be honest I don't notice it between my SL1 and SL2. I do notice the SOHC needs to be shifted down on hills while highway driving and I found that annoying.
Mileage is stored in the gauge cluster and other than that you can use either one. The SOHC tachometer redline is 5500 where the DOHC is 6500. Speedometer reading will be correct with either.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 01-17-2019, 11:06 AM   #7
chris's sc1
thank you trottida. it would seem like less work to pull all at once. a big part of me just wishes the donor car wasnt in the shape that its in so that i would have to do all that swapping. thanks guys i believe i have a game plan now
Questions Regarding CD-30 to CD-40 Swap JFS Astra General 8 01-05-2017 01:52 AM
Hello, swap questions xnizstudio S-Series Mods 2 03-23-2015 01:36 PM
swap questions? dougrobbins L-Series Tech 4 12-22-2011 10:56 AM
Going to look at a DOHC. questions questions for the swap. RBrown20 S-Series Mods 7 03-16-2009 07:53 AM
Swap Questions djsimm89 S-Series Mods 6 02-26-2008 12:33 PM
