Old 01-10-2019, 01:37 PM   #1
Rj 2000 LS2
Rj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the rough
2000 L-Series 3.0L Sedan
Default New Rear Rotors and Pads
I figured this would be an easy job, but again I stand corrected. 19 mm Caliper bolts are not moving nor is the hard brake line and I don't want to break it. Any suggestions? I am without air tools for this repair.
Add to Rj 2000 LS2's Reputation
Rate the quality of this post and help Rj 2000 LS2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rj 2000 LS2 is offline   Reply With Quote
Old 01-10-2019, 03:44 PM   #2
Default Re: New Rear Rotors and Pads
Are you aware caliper bolts are factory loctited to prevent them from loosening? 59ft-lbs for tightening, probably more to remove. I use a box wrench and a heavy rubber mallet to loosen them otherwise I position myself for pulling on the wrench hard to loosen them. 12ft-lbs for brake lines, likely more since brake fluid absorbs moisture and allows steel to corrode, setting up a mechanical equivalent of loctite. If you don't have to disconnect brake lines, don't. Its going to be difficult enough to break loose bleed screws if you bleed brakes.
Old 01-10-2019, 04:16 PM   #3
floridasl22002
The only suggestions I can offer are;
1) - Clean down the bolt and brake connection area as best you can and use some PB Blaster over a day or so. That may help with any loosening.
2) Use a breaker bar on the wrench sockets to try and loosen the caliper bolt.
3) For the brake pipe connection are you using a proper brake Flare wrench?
4) You can also try using heat. Whilst oxy-acetylene will heat them up quickly, DIY's like us can probably only use a propane torch. I had cause to use one for some hard to come off bolts at the back end of my son's L300. Lowe's sell a propane torch with bottle for about $12.00 or so.
If you are without air tools, I can recommend an electric impact wrench that Harbor Freight do. It's normally around $40.00, but with a 20% coupon I got it for a little over $30.00. I was sceptical if an electric impact wrench could be up to the job, but it's been a gem. It will loosen anything you care to throw at it. I wasn't going to invest $150.00+ in a compressor + tools, when it did the job for far less.
Failing all these, the only other suggestion is to bite the bullet and take it into a local trusted garage and either get them to do the job OR if possible, see if they can do the loosening job for you, then you do the rest. Depends on how well you know the garage.
Old 01-10-2019, 10:41 PM   #4
Rj 2000 LS2
Here's what I did. I seriously cranked on the bolts and they didn't move so that played a huge roll in deciding pads are good enough for now. I elected to only swap out the pads and leave everything else in place until next summer. The pins were is rough shape, but I think they will be fine for a few months. Neither pair of shoes had the spring installed. Well, one side did, but it crumbled when I pulled the shoes. The rotors were worn, but worn evenly without any major groves. It's just too cold to be tackling a job like this in the Wisconsin winter! At least the grinding is over with. I'll try to find new pins and springs (if available) and install the rotors and new pads this summer. This being the back brakes, maybe it doesn't matter much. The fronts are brand new.
The car brakes straight and clean with no noise. I might have just gotten lucky.
Thanks for the ideas...
Old 01-10-2019, 11:30 PM   #5
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Back brakes really donít do too much so next summer will be fine. I replaced one rear rotor on my car this last year because it had some runnout.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
I have Saturn L rear brake rotors & pads saturn_rings L-Series Tech 1 04-06-2014 09:49 AM
FS: Full front and rear brake pads and cross drilled zinc coated rotors KillerX Astra General 15 04-13-2012 07:39 PM
150,000 km on original brake pads, then replaced pads & rotors dontbreakonme Ion Tech 1 03-28-2012 02:06 PM
FS: NEW OEM rear brake rotors/pads for '91-'96 SC/SC2 M.Piedlourde Classifieds 2 05-19-2003 04:40 PM
New pads with new rotors? ym42 Miscellaneous Tech 3 04-26-2003 11:29 AM
