Old 12-06-2018, 05:15 PM   #1
Cavell
2004 VUE 3.5L
Default 05 limp mode?
found an 05 w/130k miles and 5spd that is in limp mode. seller will take $400. i read a lot about the brown wire to the ecm and to check the throttle blade moving and so on. has newer tires and is real clean. i dont feel like doing major stuff now that it is cold. isnt tracking down an elec bug fairly simple in vues?
Add to Cavell's Reputation
Old 12-06-2018, 07:50 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 05 limp mode?
Chasing wiring issues is fun (and typically easy) if you have warm place to work*, good diagrams and good test equipment (meter, code reader, test light).
* I note you live in deep freeze zone.
I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
Old 12-07-2018, 09:51 AM   #3
Cavell
2004 VUE 3.5L
i have done 3 vues in 2yrs. i have my equinox now. i felt like doing the heads on the 3.0 since it was springtime. nice weather. this vue might take up garage space which i dont like in the winter.
Old 12-10-2018, 10:44 AM   #4
Cavell
2004 VUE 3.5L
still for sale. seller said it has newer 17" rims with 1yr old tires.
i took apart my rear driveshaft this weekend. finally got the seized yoke pulled off the splined shaft. pops took it down to a shop and the 20T press did not budge it. but i kept at it. now i can order the carrier bearing. i think having working awd is probably a good thing. at least i can tell next buyer that it has a refurbished support bearing.
Limp mode WM.Mike Vue General 1 01-11-2018 11:03 AM
Limp mode - need help marianboa Ion General 4 08-13-2017 01:38 AM
LS2 in Limp Mode wrytoast L-Series Tech 11 03-30-2017 08:18 AM
Limp Mode - Still Winter6 Ion Tech 1 08-27-2014 02:02 PM
03 Vue AWD v6 3.0L in Limp Mode adidas0030 Vue General 13 02-27-2014 01:17 AM
