Old 12-05-2018, 02:57 PM   #1
rfisher
rfisher is on a distinguished road
Default question on correct torque wrenching procedure
hi sages- this question is for those who have experience using a torque wrench properly when tightening the castellated nut on the front axle shaft. this is the nut through which there is a cotter pin to prevent it from turning. you may remember a few weeks ago I did a front wheel bearing r and r on my 2001 Saturn L100 and started a thread. when you strong arm the torque wrench on this nut, how do you block wheel and rotor best , to avoid damaging the internal trans parts? should the wheel be off and you stop the hub from turning by blocking the hub lugs with a crow bar. I am concerned about transferring that torque force to the trans through the axle shaft. doing it with the wheel on and having the tire on the ground and chocked would stop it from turning but not sure this would allow the wheel and hub to be pushed in sufficiently . probably an extremely simply answer to this . thanks tons bob f
Add to rfisher's Reputation
Rate the quality of this post and help rfisher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rfisher is offline   Reply With Quote
Old 12-05-2018, 05:53 PM   #2
floridasl22002
Default Re: question on correct torque wrenching procedure
Bob,
I followed the Haynes Manual which states the wheel should be on the ground when doing the tightening of the hub nut. That way the weight of the vehicle is limiting drive shaft movement.
Here's what the Haynes Manual states. I followed this when I did my transmission repair and had to remove, then reinstall the drive shaft....
1) Install the wheel and lug nuts then LOWER to the ground (I removed the pop out Saturn badge on the wheel so I had access to the hub nut)
Torque Tightening Procedure as per Haynes Manual (REMEMBER WHEEL IS ON THE GROUND)
Step 1: Tighten to 74 to 118 ft lbs/100 to 180 Nm
Step 2: Loosen nut until it's able to turn by hand
Step 3: Tighten to 15 ft lbs/20 Nm
Step 4: Turn additional 90 degrees
After Step 4, you would install your cotter pin.
You would then need to raise the wheel and remove in order to reinstall the pop out Saturn badge.
Hope that helps
Old 12-06-2018, 08:39 AM   #3
rfisher
hi floridas- appreciate your response. on reflection thought torqueing the nut with the wheel on and the wheel lowered would cause the axle shaft to draw out a bit to compensate for steering movement when eluding coppers on tobacco road. will use your instructions. the axle does telescope a bit. thanks tons bob f
Correct Coolant and Bars Tablets - What's Correct nkb97sl1 S-Series Tech 5 08-27-2015 03:52 PM
Cam cap/bolt Removal Procedure Question TwinRevver S-Series Tech 14 08-07-2011 11:06 PM
O2 sensor question, correct me if im wrong TeamBSR1 S-Series Tech 2 12-08-2010 01:42 PM
Need correct bushing replacement procedure desired name Ion Tech 7 03-09-2008 08:57 PM
Torque spec question OU812 S-Series Tech 1 10-25-2007 10:58 AM
