Old 11-21-2018, 02:26 AM   #1
id4rox
id4rox has a spectacular aura aboutid4rox has a spectacular aura aboutid4rox has a spectacular aura about
Dizzy Mult elec. issues, BCM/ECM or a dying ion (07)?
Aloha gang. My 07 Ion has about 105K miles, and in the last 3 months it's had 3 electrical issues. I'm not sure if these are genuine independent problems, or a symptom of a failing ECM/BCM. Any thoughts?
3 months ago my power door locks started acting up. They unlock 100% of the time with the fob and with both switches, but 97/100 times they do not LOCK with either the fob or either switch. The BCM/ECM (passenger side console, whichever it is) makes an audible click when trying to lock. Tried switching/swapping all fuses and relays to no avail. Read it might be the BCM.
Yesterday, my power steering randomly went out and showed the PWR STR warning. After getting home and sitting overnight, things were fine. I've no outstanding recall repairs for this issue.
Today the check engine light came on with P0121, TPS A.
I feel like it's too much of a coincidence. I can 'clean'/replace the power steering motor if needed, but the fact the TPS warning came one so close is strange. Makes me feel like a BCM/ECM issue in general. Any thoughts from anyone would be appreciated. I'll follow the guide to try and salvage the power steering motor. The door locks are the most annoying issue since I need to manually LOCK them.
Add to id4rox's Reputation
Rate the quality of this post and help id4rox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
id4rox is offline   Reply With Quote
Old 11-21-2018, 01:42 PM   #2
Default Re: Mult elec. issues, BCM/ECM or a dying ion (07)?
Door locks, whether using switches or remote, are controlled by the body control module. The ecm runs the EFI system for the engine. You might have to determine if the door switches are preventing doors from locking by disconnecting door switches from interfering with remote use. This may help determine if the bcm is faulty. The bcm has many functions besides remotes, Passlock security and door operation. Include instrument panel, OBD II communications to the OBD II port, interior/exterior lighting, communicating with ecm, abs, and airbag modules and you have an idea of how much the bcm controls.
Dying motor caused by dying fuel pump, but WTH was that knocking? Upstate Saturn S-Series General 3 12-29-2014 11:23 PM
2001 SC1 issues with dying mtdew0000 S-Series Tech 24 02-19-2013 02:44 PM
Wiper Motor elec issues?... Delor Ion Tech 4 04-03-2010 09:30 AM
elec. short yogi1200 S-Series Tech 6 03-01-2010 04:23 PM
96SC2 P0300 Mult Misfire---Help mamalujo2003 S-Series Tech 5 07-01-2008 03:51 AM
