Old 11-20-2018, 11:58 PM   #1
sc2 saturn
sc2 saturn is on a distinguished road
Default passenger side studs/ engine mount
what is the torque spec for these two items i can't find anything for the studs
haynes book says right front mount to block bolts 1992 + later is 37 and then on the next page it says (engine mount) 1998-1999 is 150in-lbs which is correct?
Add to sc2 saturn's Reputation
Rate the quality of this post and help sc2 saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2 saturn is offline   Reply With Quote
Old 11-21-2018, 12:04 AM   #2
Waiex191
Waiex191's Avatar
Default Re: passenger side studs/ engine mount
From my notes:
Engine Mounts:
--Front Mount to Block 52 ft/lbs
--Front Mount to Front Cover 37 ft/lbs
Edit: all data diy
Motor Mount-Front-to-Block 70 Nm (52 ft. lbs.)
Motor Mount-Front-to-Front Cover
(Torque Axis Engine Mount) 50 Nm (37 ft. lbs.)
Motor Mount-Rear-to-Block (LH and RH) 48 Nm (35 ft. lbs.)
Torque Strut-to-Cradle Bracket and Engine Front Mount-RH
(Torque Axis Engine Mount) 50 Nm (37 ft. lbs. 37 in. lbs.)
Upper Engine Mount-to-Front Cover and RH Frame Rail Bracket
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-21-2018, 04:45 AM   #3
sc2 saturn
Originally Posted by Waiex191 View Post
From my notes:
Engine Mounts:
Edit: all data diy
front cover my understand that's referring to the studs that go into the cover? and also do u have to use any thread locker like loctite (blue) or on the nuts that's on frame or motor?
Old 11-21-2018, 09:30 AM   #4
Studs to front cover: 18ft/lb
All 5 nuts on the mount: 37ft/lb
Lower dog-bone cradle bracket bolts: 37ft/lb
(all)dog-bone to bracket bolts: 52ft/lb
Lower dog-bone engine bracket bolts: 52ft/lb
Trans mount to cradle nut: 37ft/lb
Trans mount to trans: 24ft/lb
Trans dog bone bracket to trans: 40ft/lb
Loctite isn't called out in the manual, but I believe factory bolts have red colored thread locker on them before 1st use. I believe it's Loctite 'blue' locking quality, 'red' is usually reserved for internal engine bolts and key-life suspension bolts.
Old 11-21-2018, 09:54 AM   #5
Waiex191
Waiex191's Avatar
Using my google superpowers, I found this:
http://www.saturnfans.com/forums/sho...d.php?t=145914
Studs 9-11 ft lbs
And I would use blue locktite.
Skip to the bottom of the thread to OldNuc's post.
Bryan Cotton
Old 11-21-2018, 10:06 AM   #6
RobertGary1
Yea the studs should be next to nothing. You’re just seating them. The bolt doesn’t stretch until you add the nut.
-Robert
Old 11-21-2018, 04:44 PM   #7
https://drive.google.com/drive/folde...9s?usp=sharing
Uploaded TSB-01-T-30A to google drive. dunno why I didn't think of google drive earlier for sharing docs
This thing apparently vanished from the interwebs, or at least is hard to find.
Installation starts at page 4.
Engine mount studs Bernie S-Series General 10 04-22-2011 06:13 PM
Engine mount studs wishihadacamaro S-Series Tech 5 03-06-2009 12:47 AM
Getting the studs out (upper engine mount) 1999greenSL2 S-Series Tech 8 08-24-2007 03:06 PM
engine mount studs - how to know. colonelhogan44 S-Series Tech 4 12-09-2006 09:26 PM
Lower engine mount - Passenger side. JS593 S-Series General 2 01-06-2006 10:32 PM
