Old 11-19-2018, 03:29 AM   #1
SlayZombi
SlayZombi will become famous soon enough
2001 SL
Default Intermittent Problem (Of Course)
So I've got a bit of an issue with my '01 manual SL. When I go to start the car up, 9/10 times it will go right away. The other 1/10 of the times, it cranks normally but just WONT catch. You could sit there holding the key in the "start" position and it'll keep cranking strong. To fix this issue, I have the stop cranking, wait a sec, and try again and ALWAYS on the second time it starts up right away. Today, when I tried to crank the second time I got this scrapey/grindy noise like the one you get when you crank a car when it's already running. Not sure where to go with this. Flywheel maybe?
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
Old 11-19-2018, 09:00 AM   #2
Waiex191
Waiex191's Avatar
Default Re: Intermittent Problem (Of Course)
On my '98 I find my starts are always good if I turn the key to run and let the fuel pump cycle. Pressure must be leaking back through the return. Otherwise I have a similar issue, especially if it has sat overnight or at work all day. The '99 has no issue like that though.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-19-2018, 09:01 AM   #3
toggenburg
toggenburg's Avatar
Did you glance at the tachometer, maybe it was already running quietly?
Sometimes just holding the key to ON for 2 seconds, you will ensure the pump has PRIMED, and then turn to START. Maybe, your fuel filter is clogging, OR the pump is starting to fail.
intermittent SL2 starting problem goodmanm S-Series Tech 0 12-18-2013 08:12 AM
Intermittent Starting Problem. SaturnIONSLVUE Vue Tech 12 03-29-2009 04:51 PM
Intermittent problem ron71157 S-Series General 2 06-15-2007 12:34 PM
Intermittent start problem '97 SC2 cabo5150 S-Series General 0 12-14-2004 09:50 PM
ABS intermittent problem TedL S-Series Tech 10 02-04-2004 11:34 PM
