Old 11-16-2018, 10:38 PM   #1
Amak
Amak is on a distinguished road
Default Gen 3 Intake Manifold Vacuum Line
This coupe is one issue after another >.<
Anyway, I'm taking the intake off to install the metal tube for the coolant fix (kept trying to cut in car, couldn't do it). In the process, like many before me, I broke the vacuum hose that runs over the top of the valve cover. I was able to salvage the connectors but I cannot find the diameter of it anywhere. Does anyone happen to know the hose diameter so I don't have the auto parts guy guessing?
On top of that, since I don't know the exact length, I was planning on getting like 2ft and trimming it. Is vacuum line normally rubber so I can just cut it with scissors?
Add to Amak's Reputation
Rate the quality of this post and help Amak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Amak is offline   Reply With Quote
Old 11-16-2018, 11:02 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Gen 3 Intake Manifold Vacuum Line
Its just rubber tubing.
I believe its 3/8" ID, but to be sure, just take one of the connectors into the autoparts store and make sure.
Old 11-17-2018, 07:38 AM   #3
trottida
trottida's Avatar
Just use shrink tubing to repair it.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 11-17-2018, 05:02 PM   #4
Keblar
Keblar is on a distinguished road
That's what I did with mine and it seems to be holding. I also thought about using rubber Vac hose with the same inside diameter as the OD of the original plastic tubing (is it plastic, or is it just hardened?) to use as a splint.
2002 SL2 ~300k Miles
Add to Keblar's Reputation
Rate the quality of this post and help Keblar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keblar is offline   Reply With Quote
Manifold Vacuum Leak... OlHillbilly S-Series General 2 01-24-2015 01:47 PM
2003 ion intake manifold vacuum ports circa.1741 Ion Tech 0 12-25-2013 11:31 PM
Coolant line on back of intake manifold? fetchitfido S-Series Tech 6 08-10-2009 03:34 PM
Vacuum manifold on SOHC 92 blue92 S-Series Tech 6 06-15-2008 11:08 PM
manifold vacuum testing graysl S-Series Tech 5 05-11-2006 05:43 AM
