Old 11-16-2018, 08:44 PM   #1
Junkman2000
Junkman2000 is on a distinguished road
Question 94/95 swapped engine with 01.. High revs?
So my friend loves his sc1. But it's engine is just done.
He buys a used motor from a 2001..
I install it, with the 94/95 intake and tbi... I swapped all the sensors to keep the older system happy... Fires up runs awesome... high idle never goes away.
I have a new temp sender coming tomorrow, other suggestions?
Also, same transmission but now almost no pedal? New clutch disk installed... I have a new slave coming tomorrow, other ideas?
Thank you in advance for any input you care to offer
Add to Junkman2000's Reputation
Rate the quality of this post and help Junkman2000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Junkman2000 is offline   Reply With Quote
Old 11-17-2018, 08:56 AM   #2
Default Re: 94/95 swapped engine with 01.. High revs?
If the coolant sensor on the '01 engine is round nosed, it may be damaged and running the engine rich/higher idle. The flat nosed brass sensor addresses this problem. Was the tbi ever overhauled/rebuilt? The fuel pressure regulator and injector are wear items.
High revs at park and super low revs at start Zuke24 S-Series Tech 6 02-26-2014 01:07 PM
Just cleaned my throttlebody, now engine revs super high? saturn92260 S-Series General 15 07-16-2009 11:09 AM
'93 Saturn SW2 engine revs high when shifting cyclewagon S-Series Tech 1 11-18-2008 09:33 PM
High pitched noise (sort of like a whine) as engine revs? bigtoque S-Series Tech 3 04-11-2008 11:56 PM
Low Coolant, smoking engine, then high revs... Padge S-Series Tech 6 09-16-2006 12:14 AM
