Old 11-16-2018, 12:58 AM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default Radiator Advice
It goes against who I am to even post this, but I am in a tight spot. My radiator has a leak, and it looks like it is leaking where the plastic meets metal on the drivers side. I am against this, but I am wondering if there is anything that could be safely used in the system to plug the leak without doing ANY kind of other harm? It is a 95 SL2 with an automatic so the radiator has the trans cooler on the side with the leak.
07/2018-PRESENT 1995 SL2
04/2009-04/2019 1994 SL1
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 11-16-2018, 01:51 AM   #2
Ionizen
Ionizen is on a distinguished road
Default Re: Radiator Advice
Look up K Seal. Itís a copper/ceramic based product. I cracked a new radiator an my explorer in a rear end accident. K seal fixed the leak right up. It Works great and wonít hurt anything else.
Add to Ionizen's Reputation
Rate the quality of this post and help Ionizen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ionizen is offline   Reply With Quote
Old 11-16-2018, 10:06 AM   #3
cgg17
cgg17 is a jewel in the roughcgg17 is a jewel in the roughcgg17 is a jewel in the roughcgg17 is a jewel in the rough
cgg17's Avatar
Just replace it. I got one at our local NAPA for 99.99 before tax. If you pour anything in there you run the risk of plugging your system and ruining your car.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-16-2018, 10:06 AM   #4
toggenburg
toggenburg's Avatar
For so little money ($42), and shipped right from California too.
https://www.ebay.com/itm/New-Radiato...hb1k:rk:7:pf:0
Or google Silla radiators for a little more money.
Old 11-16-2018, 10:21 AM   #5
trottida
trottida's Avatar
The plastic is known to crack in that area over time due to expansion and contraction. While some have fixed the crack temporarily it almost always results in eventually replacing the radiator. Save yourself some time and aggravation and just replace it.
Here's what it looks like front and back. It typically hemorrhages into the engine bay as it did in this case.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-16-2018, 10:43 AM   #6
May want to do some reading - I don't think it gets good until around page 2 or 3, as the early attempts failed shortly afterwards
http://www.saturnfans.com/forums/sho...d.php?t=153794
edit: original fix lasted about 15 months, see post 46 for a longer lasting one
Old 11-16-2018, 01:38 PM   #7
amazinghl
Under $50, just replace it and save yourself the headaches.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 11-16-2018, 02:46 PM   #8
Waiex191
Waiex191's Avatar
I am a strong believer that repairs in a bottle are bad. This is an easy replacement.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-16-2018, 05:34 PM   #9
StrnWolf
1994 SL1
I strongly agree and am too, but right now I cannot replace it. I won't be able to confirm it until I remove the radiator but there is a 75% chance it was purposely damaged. When the engine and radiator is fully cold, and I start the engine, thats when it just pours out about 1/6 to 1/4 of the coolant tank is lost during warm up, but when Its warmed up I only lose tiny amounts, and zero amount if I relieve the system pressure once fully hot.
On a related note, I plan to buy a radiator from RockAuto for my 95 SL2 Automatic, and I don't think I can buy ACDelco, so I am wondering if, among the other brands, there is any brand for my car from there that I should AVOID?
And another related, if there is any actual number on how much transmission fluid is lost during the swap when engine is warmed up, so I know I have enough fluid on hand.
Old 11-16-2018, 06:04 PM   #10
Cheyne
2000 SL2
The Delphi was OE for a few years, but I'm not sure about 95. Some are still available for ~120 on ebay.
That said, for the price point on RA, I would certainly get the Denso if not going with Delphi. I've used Denso radiators on other vehicles with absolutely no problem when OE is no longer available. I wouldn't bother with the Spectra based on personal experience when working on a rush repair for family.
You won't lose much transmission fluid on the repair. A quart on hand will be more than is needed.
Add to Cheyne's Reputation
1999 Saturn SL2 Automatic - Radiator Advice! okaminara S-Series Tech 2 08-07-2014 01:47 PM
radiator transmission tube (manual; radiator replacement) sw87 S-Series Tech 3 03-27-2010 09:15 PM
Coolant (radiator/block) Flushing Advice ... TomM96 S-Series Tech 1 05-16-2008 06:02 AM
Deer Strike - need advice on replacing top mount radiator support beam cwtae S-Series Tech 0 11-24-2005 03:51 PM
Advice, please on sway bar & strut brace advice for 1998 SL2 DOHC. TimothyD S-Series Mods 12 06-21-2002 12:34 PM
