Old 11-16-2018, 12:02 AM   #1
jillybean
jillybean is on a distinguished road
Default 2008 Aura possible ECM issue
Hello everyone,
I started my Aura yesterday, and the check engine light went on. I went to my local Auto Zone, and they told me that the error code said that there was a problem with my ECM.
I checked around, and it's about $200 to get a new one, but I hear that I have to go to the dealer to get it reprogrammed (and I bet that's expensive)? Is there a way to reprogram it myself?
Also, I just started my car today, and the check engine light is off now. I don't use my car very often, and it's gotten very cold the last couple days where I live. Could the cold have made the error code come up, and the ECM is not really about to fail?
I have the 4 cylinder XE model in case that's important.
Thank you!
Add to jillybean's Reputation
Rate the quality of this post and help jillybean reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jillybean is offline   Reply With Quote
Old 11-19-2018, 04:04 AM   #2
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Default Re: 2008 Aura possible ECM issue
Do you have the code...Since the CEL went out whatever code was present was intermittent and has cleared so the ECM is probably not failing.
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-20-2018, 11:53 PM   #3
jillybean
Hi! Thanks for the reply. The error code according to Autozone was P0010.
Old 11-21-2018, 01:57 PM   #4
Search within this forum for similar P0010 error code issues and any solutions. You can find definitions from a Google search. It's rarely an ecm fault when many presume a computer cpu failure. Try leaving and running a laptop in a car 24/7, 365 days a year in every season and temperature extremes and see if it lasts longer than car electronics.
While AutoZone, Advance Auto and other auto stores may provide free readings of error codes, they're not experts in auto diagnostics enough to suggest what failed. Their best attributes are free readings and tool loan programs. While I'm not an expert on auto diagnostics, experience/electronics background/getting dirty/mechanical skills and the overwhelming desire to keep money from leaving my wallet to support repair shops seems to work for me as well as many here willing to do the same. Dealers and repair shops are doing fine without my support.
Old 11-23-2018, 06:28 PM   #5
dano92sl
dano92sl has a spectacular aura aboutdano92sl has a spectacular aura about
2008 AURA XR
Do a search on the code on this site. Basically you need to replace the intake and exhaust camshaft actuator solenoids (different code for each, not the senders). One will usually go first, but they recommend replacing both. I found a pair on Amazon for $40 delivered. Located next to the spark plugs on top of the engine. Electrical connector on top and one bolt for each.
Add to dano92sl's Reputation
Rate the quality of this post and help dano92sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dano92sl is offline   Reply With Quote
Old 11-23-2018, 09:59 PM   #6
imaddicted2u
2008 AURA XE
Yep, P0010 is not a failing ECM code. It's for "A" Camshaft Position Actuator Circuit (Bank 1)
https://www.obd-codes.com/p0010
Since the check engine light went off the code must have went away, I wouldn't mess with anything until it comes back, if it comes back.
Here are steps to replace.
https://www.youtube.com/watch?v=tUt1rB2o8g4
and
https://www.youtube.com/watch?v=gUjdgn_HQz0
2008 Aura XR Transmission Issue puffcat614 Aura General 1 08-01-2018 01:19 PM
RVS Issue on 2008 Saturn Aura saturnaura08 Aura General 3 04-07-2016 01:15 PM
2008 Aura XE 3.5 Error Code Issue Tajee Aura General 6 05-19-2015 01:51 PM
New 2008 Aura XR Firebat Aura General 4 04-14-2008 05:46 AM
New 2008 Aura Motorhead62 Aura General 29 01-05-2008 06:22 PM
