Old 11-14-2018, 04:51 PM   #1
MghtySaturn
MghtySaturn is on a distinguished road
Wrench Car won't stalls after warm up
I have a 1999 Saturn SL1 that once it get to normal operating temperature. It seems that the car runs out of gas when it stalls. I have replace the fuel filter. The egr and throttle body are clean. I have also replaced the catalytic converter. I have also replace the ects because it was running rich. Any suggestions would be greatly appreciated.
Add to MghtySaturn's Reputation
Rate the quality of this post and help MghtySaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MghtySaturn is offline   Reply With Quote
Old 11-14-2018, 06:33 PM   #2
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Default Re: Car won't stalls after warm up
fuel pump maybe ?
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is online now   Reply With Quote
Old 11-15-2018, 12:19 AM   #3
Cheyne
2000 SL2
Sounds like an intermittent cps failure. Check for spark across the coil towers when warmed up and the stall occurs.
Add to Cheyne's Reputation
Old 11-15-2018, 07:10 AM   #4
MghtySaturn
Wrench Re: Car won't stalls after warm up
Could it still be my fuel pump if I can hear it come on when I turn the key on? How do I check it to be sure?
Old 11-15-2018, 11:02 AM   #5
Mileage? The best way to assess fuel pump and pressures is with a fuel pressure gauge connected to the fuel rail test valve. AutoZone or Advance Auto should have loaners for this purpose. A credit card copy or cash deposit ensures loaners are returned. If it can left connected, check for pressures when the engine dies and again when restarting.
Old 11-15-2018, 02:00 PM   #6
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
I agree with the CPS (Crank Position Sensor); when I had my 3rd gen wagon, it did exactly this, and that's exactly what it was. It's a little difficult to reach, but not terribly difficult to replace.
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
1994 SL2 - Nelly Belle
Current:
1997 SL1 - Cinnamon - 285K
1996 SL2 - Blanca - 36K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 11-15-2018, 10:02 PM   #7
MghtySaturn
My car has 218,000 miles. I am not getting any codes.
Old 11-15-2018, 10:07 PM   #8
Cheyne
2000 SL2
CPS will not throw a code and testing for failure due to lack of spark doesn't require a loaner tool. It's an easy test that you can perform immediately for a common failure that causes the symptoms you're describing.
Old 11-16-2018, 10:35 AM   #9
Yep. See Cheyne's post #3.
Typically, let it cool down about 10~20 minutes and it will start right up again like nothing happened.
Car stalls while idling once it's warm, help! joshjames023 S-Series General 49 11-14-2018 02:33 PM
SL stalls when warm big easy S-Series Tech 4 11-02-2010 05:37 PM
Saturn stalls when warm big easy L-Series Tech 1 11-01-2010 07:20 PM
stalls when idling warm mannsjp S-Series Tech 3 03-28-2010 07:52 PM
saturn stalls after it gets warm? creepyrat S-Series General 26 05-31-2006 06:25 PM
