Old 11-13-2018, 06:52 AM   #1
GerriceM
GerriceM is on a distinguished road
Default 1999 sl2 does nothing!!! Please help!!
Hello. I just got a 1999 SL2 and it wouldn't start. I had a crank position sensor put in and everything tightened and greased up. Drove yhr car to work Saturday and when I got off it was dead and has been that way ever since. I turn the key door chimes radio works dash lights up but no crank or any sound just silence...I live in Chicago and it getting too cold to keep walking any ideas
Add to GerriceM's Reputation
Rate the quality of this post and help GerriceM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GerriceM is offline   Reply With Quote
Old 11-13-2018, 07:54 AM   #2
Waiex191
Waiex191's Avatar
Default Re: 1999 sl2 does nothing!!! Please help!!
The starters in our S Series tend to fail. If you have everything but the crank that is likely. Manual or auto transmission? If a manual you can bump start it. Jumper cables don't help with a bad starter.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-13-2018, 10:38 AM   #3
trottida
trottida's Avatar
Another trick you can try and it may give you a start or two. Take a 2 foot piece of dimensional lumber (2"by 2" perhaps) place it on the starter from above (if you can) and tap on the end of the wood while someone cranks the key. The vibration is sometimes enough to get another start out of it. Once you get it started then drive it to a shop to have the starter replaced. Don't turn it off until you get it where it needs to be for repair.
DB Electrical have the recommended starters at a reasonable cost. You can get them on amazon too.
https://www.dbelectrical.com/product...02-satrun.html
If you do it yourself, replace the top bolt with a manifold stud and nut. This makes it easier to re-install as you can't see the top bolt location. Using a stud allows you to hang the starter from it for support.
2001 SL1 MT (428,500 km @ 01/2019)
1999 SL2 MT (272,500 km @ 01/2019)
2011 Suburban LT (120,506 km @ 01/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-14-2018, 06:35 PM   #4
GerriceM
Thanks so much I'm going to try to test it but my starter is under the car so I will have to find help. Will let you know how that goes.
Old 11-14-2018, 07:14 PM   #5
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Have you read here about the magic "purple wire" on the starter? If you go under there, you might as well take a voltmeter with you and do the definitive tests.
Add to billr's Reputation
Old 11-14-2018, 07:54 PM   #6
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
make sure it has voltage on both the solenoid and the starter should be two places where u see wires . Each one should have 12 volts. ground the dvom on the car somewhere and probe with the red on each of these . better get it started cause its cold in chicago.Most junkyards sell them for 20 bucks if u cant afford a new one but at least you can get your car back. Id get a new starter on it or a junkyard one . I put a 139 duralast gold on mine never looked back . I always pay for reliabity before cheap cause my car is needed as its all i have to get around and towing is not cheap.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 11-14-2018, 07:59 PM   #7
Packard
1995
Test for 12 volts will tell you its the starter if u got volts there then its a starter . I had this happen to me at a store car was silent but dash lights up then its a starter . U can tap the solenoid to see if it will start. If this is a 5sp when mine went out i had someone push me to start my car . it has to be in gear though I think it was in 1st to get mine to start. I did it that way to get it home so i could replace my starter . As soon as I got it to start I took it home and bought a new starter and put a it in . 5speeds are good for that if starter goes you can still start with a push.
Old 11-14-2018, 08:01 PM   #8
Packard
1995
. If the starter is dead but the windshield wipers and headlights are working, the problem could be a stuck gear. ... sometimes tapping can help with this and get it working temporarily .
Old 11-15-2018, 07:15 PM   #9
GerriceM
Packard where would I tap to see if the gear is stuck? I have an automatic transmission. Also do you happen to know how reliable a DB Electrical starter is? I see they are pretty cheap compared to others. I'm thinking of getting an AC Delco but I just want to weigh my options
Old 11-15-2018, 08:17 PM   #10
Waiex191
Waiex191's Avatar
I love my DB electric starter. I put it in just before teaching my 15 year old to drive a manual transmission. That starter has seen a lot of abuse, still going strong after 6 months and 6000 miles or so.
Bryan Cotton
Old 11-15-2018, 09:15 PM   #11
Cheyne
2000 SL2
AC Delco is just a rebranded Valeo starter.
I just ordered a new Valeo starter for the shelf. Figured the car had just over 100K and why not for 24.00 delivered? I guess we'll see when it arrives.
http://proagplus.com/product/100-new...2-1-9l-1-9-v4/
Add to Cheyne's Reputation
Old 11-15-2018, 10:12 PM   #12
Are these the same starters?
Old 11-15-2018, 10:19 PM   #13
Cheyne
2000 SL2
Of course not. The DB electrical is for a Satrun. The ProAg is for Saturn.
One of the things I noticed is the notation at the very bottom of the ProAg page ...
I'm interested to see if the one that arrives has the Valeo sticker. I just ordered it today, so I can't comment on it until it arrives.
Old 11-15-2018, 10:21 PM   #14
Ahh, you noticed the misspelling...... Its a good thing no one noticed and used them anyway.
Old 11-16-2018, 10:58 AM   #15
richpin's video shows starter location, I think - basically, under the car on the backside of the engine
https://www.youtube.com/watch?v=U6awyslXkeI
I installed my DB Electrical starter on 4/20/2013 on my daily commuter car. Minimum of three starts a day (going to night classes), 5 days a week, and it is still good.
Old 11-16-2018, 06:53 PM   #16
GerriceM
Well I orderedy DB Electrical starter today and it won't arrive until Sunday I got it on Amazon Prime for $40.97 with tax and free 2 day shipping...I'll let you guys know how it turns out..me and my Aunt may just do it ourselves after watching Richpins video. On another note I have an electric moonroof and my front passenger floorboard is wet but my roof is not leaking any ideas???
Old 01-08-2019, 10:17 PM   #17
Cheyne
2000 SL2
I wanted to post back on the other source. The starter was never shipped.
Old 01-08-2019, 11:14 PM   #18
Saturn Night
The starter is on the backside of the block, directly under the intake manifold. With the correct tools, it can be replaced in as little as 15 minutes.
You will need a 6" extension, a 3" extension, a 13mm deep well socket and ratchet. All in 3/8" drive.
For the starter wiring, you will need the 13mm for the big nut. This is the one with the fusible link wiring. The purple wire can be 8mm or 10mm, depending on IF it has been replaced in the past or not.
Disconnect the negative battery terminal, BEFORE you pull it out. The starter is HOT at all times, and it will spark a ground if the ratchet touches any metal, while also touching any of the wires with power going through them.
A set of driving ramps or jack stands will give you the clearance to get under the car for replacing starter motor.
Starters can fail on any car, and you can source a cheap, used starter from a wrecking yard at: www.car-part.com
Original starters were manufactured by Valeo, and were high quality units. I still had my original starter motor, on my 1995 SC2, when I purchased it in 2016. The car was 21 years old and had 163,082 miles on it. When I got close to 175,000 miles, it finally went bad. Blew the plastic safety cap off, and moisture got into it.
Old 01-08-2019, 11:16 PM   #19
Saturn Night
Stock sunroof/moonroof options had drain tubes that route through the frame of the csr. They can get clogged with debris.
Other causes of a wet floor board can be a leaking weather strip, as they are rubber and deteriorate.
Old 01-09-2019, 10:05 AM   #20
trottida
trottida's Avatar
Wet floor boards specifically on the passenger side can also be the HVAC air intake gasket is missing or damaged. This is the oval shaped foam and screen gasket located in the engine bay on the passenger side near the base of the window. The foam gasket gets sandwiched between the body and the closed hood and keeps water out of the HVAC intake while allowing air in through the internal structure of the hood. The screen is there to keep debris and pests out of the HVAC passages.
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
1999 Sw2 SWAP TROUBLE... 1996 in a 1999 sw? FAILURE??? SW2STICKySHIFT S-Series Tech 28 01-18-2012 01:24 AM
1999 SC2 1999 SC2 Manifold replacement SC2Saturn S-Series General 8 05-14-2011 07:36 PM
1999 sl2 shedstein S-Series Tech 3 04-01-2011 08:41 PM
1999 sc2, help please! sc2_44 S-Series Tech 13 06-13-2009 08:19 PM
1999 Sc2 Coorslight S-Series General 1 09-22-2005 09:39 PM
