Old 11-08-2018, 03:20 AM   #1
T. Thudpucker
T. Thudpucker is on a distinguished road
Default 210-25-25-210
These are the compression numbers on a 97 SL2. I am suspecting blown head gasket between 2 and 3
-no oil in coolant
-no coolant in oil
Could this be a simple matter of pop the head off, slap a new gasket, and call it a day or does anyone think this is a deeper problem? Oldnuc?
A bunch of Saturns and a truck to tow with when something breaks...
Add to T. Thudpucker's Reputation
Rate the quality of this post and help T. Thudpucker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
T. Thudpucker is offline   Reply With Quote
Old 11-08-2018, 09:39 AM   #2
Highmile
Highmile's Avatar
Default Re: 210-25-25-210
I wouldn't bother unless you at least have the mating surface machined at your local machine shop.
Been here, done this, got the tee shirt
Highmile
'95 SL1 671k and counting
Add to Highmile's Reputation
Old 11-08-2018, 10:52 AM   #3
Depends on how long it has run with a leak between the cylinders. This is a clean up and measure task to see if just a gasket will fix it or not. You measure this with a straight edge and a bright light, see light and you have a problem. You are concerned with both the head and block. This could also be valves so Without having the head off you have no idea exactly what is wrong.
Old 11-08-2018, 12:53 PM   #4
T. Thudpucker
First step will be pulling the thing, hope to do it soon.
Thank you, I forgot that burning valves is a thing. I am not the one driving the car so I don't know how it's being driven...
When I get it apart I shall post what I find
Old 11-08-2018, 01:05 PM   #5
T. Thudpucker
<accidental double post>
Old 11-10-2018, 12:06 AM   #6
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Pick an pull something at a wrecker if u want to rebuild yours cheap.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 11-10-2018, 02:42 AM   #7
SlayZombi
SlayZombi will become famous soon enough
2001 SL
Gonna be a replacement head. It's difficult to properly restore a warped head and it's better off the avoid any potential issues that come up from improper restoration by just sourcing another non-blown head gasket head.
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
