Old 11-08-2018, 03:06 AM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default Torque Specs for Exhaust
I need to replace my exhaust manifold gasket, which I can say is most likely because I was a victim of a bad mechanic. They cut my brand new fuel filter on purpose, so I have almost no doubt they did this because somehow the studs are not screwed into the engine fully any more, not even finger tight. So, I need to know the proper torque for the studs in the engine and for the nuts on the stud. Also, would like to know where I can get new nuts if possible. I have a 1995 Saturn SL2
07/2018-PRESENT 1995 SL2
12/2009-PRESENT 1994 SL1 (FOR SALE!)
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is online now   Reply With Quote
Old 11-08-2018, 09:29 AM   #2
Default Re: Torque Specs for Exhaust
Studs: 106 in/lbs (8.83 ft/lbs)
Nuts: 16 ft/lbs
If you have a junkyard nearby the intake manifold studs are the same thread pattern, only longer on the manifold side (possibly on head side too), if you get a high(er) $$ item they'll probably throw the bolts in for free. Otherwise I'd try Home Depot or Fastenel, I'd bet Fastenel is more likely to have the required metric thread.
At the very least I'd get 2 intake manifold studs with nuts to have on hand in-case the starter dies, replace the bolts for the starter with the studs and not fight blindly for hours getting the starter back in.
Old 11-10-2018, 01:27 AM   #3
StrnWolf
1994 SL1
Nuts: 16 ft/lbs
Thank you! Do you also know what size bit I need for the studs? I do not have the socket for that size so I need to buy a set with the right size for it.
Old 11-10-2018, 02:30 AM   #4
Greg1
Greg1's Avatar
1997 SW2
It's an E7. It is in a set I got at Harbor Freight.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-10-2018, 09:47 AM   #5
It's a size E"snaps off as soon as you put the socket on it"
I was thinking E10, but it is pretty small so E7 could be right.
Pretty much every one I've taken out the nut locked itself to the stud and it came out as a bolt.
Old 11-10-2018, 07:21 PM   #6
StrnWolf
1994 SL1
Yeah, I think the smallest size I have is E 10 and the whole stud fit through the center down to nut. You may imagine how angry I was when even it was that loose I managed to move the stud in and out.
But also, yeah seems my nuts are stuck on too. Think ill pick some up from local yard and get them seperated to be all ready for my Saturn. I was thinking an E socket with a flare nut wrench to separate them while not in the engine.
Old 11-11-2018, 11:53 PM   #7
TomM96
pretty sure the thread is M8X1.25 nut hex=13mm
It is said the OEM intake & exhaust studs are same composition...
Advance Auto sometimes has Ex Man studs by Dorman, which appear
to be good quality (but different length, & no torx section.
IF the car has seen a lot of roadsalt, the ExMan may be rusted on block mating face. In that case, maybe sandpaper flatter with Silicon Carbide paper on a 2"X4" wood sanding block.... That prep should last for 200kMi.
Add to TomM96's Reputation
Old 11-12-2018, 01:25 AM   #8
StrnWolf
1994 SL1
Where I live we do not have any salt, our biggest harm is heat in summer and then its just any road flooding in winter as a vehicles enemy.
Old 11-12-2018, 01:34 AM   #9
StrnWolf
1994 SL1
Is there any special way to tighten the nuts on the manifold such as a pattern or in steps or anything like that?
Old 11-12-2018, 09:15 AM   #10
Generally (most any manifold,not just s-series) you go from the inside to the outside. Kind of a spiral pattern. I didn't have an issue starting at one end and going to the other but that doens't mean someone else also won't have an issue.
Old 11-12-2018, 11:02 AM   #11
Bolt pattern as fetchitfido states.
Old 11-12-2018, 08:03 PM   #12
laser3kw
laser3kw is on a distinguished road
2000 SC1
man, your testing my OCD
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Old 11-16-2018, 12:52 AM   #13
StrnWolf
1994 SL1
Thank you all very much!
Torque Specs gmsuv 2008 Vue 2 01-31-2008 09:54 AM
Torque Specs Asinity Ion Tech 12 09-06-2006 03:41 PM
torque specs gmelton S-Series Tech 2 04-05-2006 05:42 PM
Nut Torque Specs for 1999 SL2 Torque Axis Mount todd8 S-Series General 3 05-01-2005 01:34 AM
Tie Rod Torque Specs? Flyguy405 S-Series Tech 1 12-06-2003 06:58 PM
